WrineX Posted September 27, 2023 Report Posted September 27, 2023 Well i got my first charger ready for testing. I changed up the looks this time since i want to be able to make the NP50 and BX1 versions with the same footprint and some of the components. (so i dont have to keep materials for 3 chargers on stock) needs some charge cycles and loading unloading tests it charges 8 batteries at once all at 400mAh so a 1000mAH batteries should be done in around 3 hours +- Quote
resoNate3973 Posted October 16, 2023 Report Posted October 16, 2023 beautiful! how are the batteries lasting?? Quote
docsound Posted August 26, 2024 Report Posted August 26, 2024 Looks great! Can it be powered with USB-C ? Can you do also a charger for Wisycom MPRLBP / Klic-8000 / CS-WMR500SL ? Quote
WrineX Posted April 4, 2025 Author Report Posted April 4, 2025 On 8/26/2024 at 11:20 PM, docsound said: Looks great! Can it be powered with USB-C ? Can you do also a charger for Wisycom MPRLBP / Klic-8000 / CS-WMR500SL ? the use a regular DC barrel plug , but with a wide range of voltage input. they take 12-30 volt so they can be used on a cart battery etc On 10/16/2023 at 5:27 AM, resoNate3973 said: beautiful! how are the batteries lasting?? i cant say, im using cheap ones for basic testing. i test every charger before it ships out. i do not overcharge them so they should last pretty long ! Quote
Wyatt Tuzo Posted April 5, 2025 Report Posted April 5, 2025 Beautiful, as always! I'm curious... would you ever consider making chargers for the (many) Shure Axient batteries? Their chargers perform perfectly well, but are a bit bulky. Having greater density would be really nice. Batt Types: SB910M, SB910, SB900 Quote
