  • 1 month later...
Seems to be a new version of the ECM-77, but the connection is plug-in power.
I considered getting one as I have two ECM-77s but it is not compatible with the UWP system. Plug-in power (commonly used in cameras and consumer wireless systems) is unbalanced while the ECM-77 BMP (wired for the Sony UWP system) is actually balanced according to the service manual.
Sony also says it is not compatible (although looks like they fired their technical writers!)
https://www.sony.co.id/en/electronics/support/accessories-audio-video-accessories/articles/00347553
If it is an ECM-77 the sound will be good.
  • 1 month later...
Thanks a lot! Unbelievable that the new Sony mic is incompatible to their own UWP-lineup..
Until now I have been using their stock mics ECM-V1BMP that come with the UWP transmitters,
and I even had to buy some new ones as the cables wore out after some time.
They work fine most of the time with a litte EQ in post, but 150 euros each for a ECM-V1BMP seems overpriced to me - considering they are not very robust.
Are there any other good options?
I work mostly for news broadcast and I have five UWP-D transmitters, so cost can be a factor.
As I dont need to hide the mics on the talent do you think maybe even getting five Rode Lavalier II with Sony adapter cable could be an option?
Or are there any other very robust and affordable options?
I know, most people here play in a totally different league..
5 hours ago, Sound said:
Thanks, they should definitely clarify this in the product description. Still quite an expensive microphone for a cheap bluetooth based system.
You can buy the ECM-77 BMP which is wired the Sony UWP system but it’s pricier than the ECM-L1. Or get the workhorse Sanken COS-11 which can be found wired for Sony systems.
I guess Sony had cameras in mind with the ECM-L1.
  • 1 month later...
I used Sony heavily in the past, my first purchased kit was Sony. And I still have a few units. Liked them much better than the popular Sennheiser.
In any case, you can wire almost any microphone out here for the Sony system, the stock ones are pretty bad.
I would offer you to buy some used Trams or B3 from me, but since I'm in the US and you are in Europe it probably won't make financial sense. Inexpensive mics that are much better than the stock one - Tram Tr50, Countryman B3, Sennheiser MKE2 (expensive new, but there's a lot of used ones out there). If the stock costs 150 euros these days I would ditch them. They are also not very sturdy compared to the ones I mentioned. For re-terminating used ones - I do it myself, but the price in the US is roughly 50-60 bucks per mic, I imagine it'll be similar in Germany. Cheers.
Just as an example - I re-terminated those: https://www.ebay.com/itm/126534117612
  • 6 months later...
Thanks for your help. I found out that its much easier to re-terminate the UWP-D Transmitter itself. Its just swapping two cables inside. So I can use any mic. What do you think of deity or rode? Are they any good and sturdy enough for the price?
Edit: Someone wrote on reddit that deity wiring is again different from sennheiser: One thing I have to note is that the wiring is different than Sennheiser cables (no fault of Deity) but just note that the instrument wires made for Sennheiser SK transmitters will NOT work with Deity transmitters.
(The line level input of SK transmitters expect signal on the ring terminal and ground the pin which is where the Deity TX packs are expecting signal from).
So is it the same as sony?
