nika paniashvili Posted December 9, 2011 Author Report Share Posted December 9, 2011 " I ordered 8 sanken mics." with 6 x TX, that would be 2 x spare lav's spare's are good, especially when your not the one whose paying Quote Link to comment Share on other sites More sharing options...
nika paniashvili Posted December 13, 2011 Author Report Share Posted December 13, 2011 another question: I have a schoeps CMIT5U mic. so if I dont use the butt-plug and go with SMQV how do I phantom feed the mic? what 48v adapters are there for this mic? as well Im planing to buy either an MK41 with CMC6 or CCM41 LG for interiors, so same advice needed here regarding powering... oh and which one of those two indoor mics would you recommend ? Quote Link to comment Share on other sites More sharing options...
soundslikejustin Posted December 13, 2011 Report Share Posted December 13, 2011 Ambient UMP II, Denecke PS1-a or PS2 are some options to consider for powering. You would then feed the mic level signal into the SQMV. I'm unsure of the pin assignment you'd use as I don't use Lectro packs like this, but it can be done. Zaxcom TRX942 is another option, all in one box. Quote Link to comment Share on other sites More sharing options...
Nick Jabour Posted December 13, 2011 Report Share Posted December 13, 2011 hello! My local production company asked me to have a look and (if needed) make changes to the list of wireless eq they plan to buy this days. the kit includes the following: 3x lectro SR/5P 6X lectro SMQV 1X lectro octopack 1X lectro HM butt-plug 1X lectro SNURI mout kit for unislot 2X Senni ew 300-2 IEM G3 for monitoring 1X Lectro ALP500 LPDA Shark Fin 1X lectro RM2 for SM transmitters nika You seem to have more spaces for SR's then you have total SR's? The octo takes 4, and the drop in would be a 5th SR unit? Now if you guys are looking at a quad pack then you have the right numbers here. Also for the Octo, you need them to be SRA's not SR's. Quote Link to comment Share on other sites More sharing options...
nika paniashvili Posted December 14, 2011 Author Report Share Posted December 14, 2011 Ambient UMP II, Denecke PS1-a or PS2 are some options to consider for powering. You would then feed the mic level signal into the SQMV. I'm unsure of the pin assignment you'd use as I don't use Lectro packs like this, but it can be done. Zaxcom TRX942 is another option, all in one box. Ambient UMP II, Denecke PS1-a or PS2 are some options to consider for powering. You would then feed the mic level signal into the SQMV. I'm unsure of the pin assignment you'd use as I don't use Lectro packs like this, but it can be done. Zaxcom TRX942 is another option, all in one box. thank you Quote Link to comment Share on other sites More sharing options...
Christian Spaeth Posted December 14, 2011 Report Share Posted December 14, 2011 another question: I have a schoeps CMIT5U mic. so if I dont use the butt-plug and go with SMQV how do I phantom feed the mic? what 48v adapters are there for this mic? Sound Devices MM-1 phantom powers your CMIT and adds a quality limiter plus monitor mix for your boom op. Quote Link to comment Share on other sites More sharing options...
nika paniashvili Posted December 14, 2011 Author Report Share Posted December 14, 2011 Sound Devices MM-1 phantom powers your CMIT and adds a quality limiter plus monitor mix for your boom op. yay thanks Quote Link to comment Share on other sites More sharing options...
Davideo Posted December 14, 2011 Report Share Posted December 14, 2011 Nobody has mentioned that you could save a hundred bucks if you get the LectroRM app for iPhones or Android phones... plus it has more features (frequency changing) over the Lectro RM2. Quote Link to comment Share on other sites More sharing options...
nika paniashvili Posted December 27, 2011 Author Report Share Posted December 27, 2011 bumping this up for maybe a dumb thought/question for sennheiser users... question might be dumb, but you know the saying I thought of the following setup: if from my recorder I output boom+slate mic to left channel of ew 300 g3 tx and mix (w/o slate mic) to right channel will it be then possible to setup 1 rx to receive left only (as mono feed) and 3 other RX's the mix only eg right channel of transmission...? didn't quite get how it works through the manual.... can this be done? or should I buy second tx for boom op/utility? Quote Link to comment Share on other sites More sharing options...
studiomprd Posted December 27, 2011 Report Share Posted December 27, 2011 " can this be done? or should I buy second tx for boom op/utility? " no, yes. Quote Link to comment Share on other sites More sharing options...
Olle Sjostrom Posted December 27, 2011 Report Share Posted December 27, 2011 Zen Buddhist, Mike? (null) Quote Link to comment Share on other sites More sharing options...
nika paniashvili Posted December 28, 2011 Author Report Share Posted December 28, 2011 " can this be done? or should I buy second tx for boom op/utility? " no, yes. wwwhyyyyyy :'( ok, another question - can neopax SM belts hold smqv tx? Quote Link to comment Share on other sites More sharing options...
soundslikejustin Posted December 28, 2011 Report Share Posted December 28, 2011 They have another size on their website called 'DB', made for SQMV and trx900lt's. Quote Link to comment Share on other sites More sharing options...
nika paniashvili Posted December 28, 2011 Author Report Share Posted December 28, 2011 They have another size on their website called 'DB', made for SQMV and trx900lt's. yes, but can't seem to find at re-sellers. what the do have is standard and SM size. at coffeysound it says that SM size fits smq/a types while on neopax site it says DB for smq/a's... got a bit confused and don't want to order the wrong one Quote Link to comment Share on other sites More sharing options...
studiomprd Posted December 28, 2011 Report Share Posted December 28, 2011 " can't seem to find at re-sellers " You could ask your favorite dealer to order you some, if they are not in stock. Quote Link to comment Share on other sites More sharing options...
soundslikejustin Posted December 28, 2011 Report Share Posted December 28, 2011 The DB size is fairly new AFAIK, and most dealers won't have them in store yet, but like senator says, they can be ordered in. Quote Link to comment Share on other sites More sharing options...
nika paniashvili Posted December 29, 2011 Author Report Share Posted December 29, 2011 " can't seem to find at re-sellers " You could ask your favorite dealer to order you some, if they are not in stock. The DB size is fairly new AFAIK, and most dealers won't have them in store yet, but like senator says, they can be ordered in. thank you! Quote Link to comment Share on other sites More sharing options...
soundslikejustin Posted December 29, 2011 Report Share Posted December 29, 2011 Not a problem, I'm ordering in some for myself, hopefully through Pro-Sound. Quote Link to comment Share on other sites More sharing options...
