PCMsoundie Posted January 11, 2021 Report Posted January 11, 2021 Is the Icon Pro Audio QCon Pro G2 Control Surface a possibility with the Sound Devices 8 series (or 633,688) in lieu of the Sound Devices CL-16 16 dedicated fader unit? Icon Pro Audio QCon Pro G2 $700. USD approx8 touch-sensitive motorized channel faders universal control surface with Mackie Control and HUI emulation 12Volt2.5A DC powered USB 2 connector 14.6lb heavy.. https://iconproaudio.com/product/qcon-pro-g2/ Quote
Erob Posted January 11, 2021 Report Posted January 11, 2021 As of right now no. The list of compatible control surfaces is: Behringer X-TOUCH iCON Platform M+ (w D2 Display) iCON Platform X+ iCON Platform B+ Mackie MCU Pro Sonosax SX-LC8+ Sound Devices CL-12 Sound Devices CL-16 So there are options other then the CL-16. I’ve heard some people love the Sonosax, I believe it’s powered via usb as well (don’t quote me on that) making it easy to use on location. I have the icon M+ and for the most part have been happy with the limited use I’ve done with it. Quote
Johnny Karlsson Posted January 11, 2021 Report Posted January 11, 2021 39 minutes ago, Erob said: As of right now no. The list of compatible control surfaces is: Behringer X-TOUCH iCON Platform M+ (w D2 Display) iCON Platform X+ iCON Platform B+ Mackie MCU Pro Sonosax SX-LC8+ Sound Devices CL-12 Sound Devices CL-16 So there are options other then the CL-16. I’ve heard some people love the Sonosax, I believe it’s powered via usb as well (don’t quote me on that) making it easy to use on location. I have the icon M+ and for the most part have been happy with the limited use I’ve done with it. I could be wrong, but the way I understand it is that those are the ‘supported’ ones. Others may still work, as long as they use the Mackie universal protocol....? Quote
Erob Posted January 11, 2021 Report Posted January 11, 2021 Rereading the FAQ’s on Sound Devices website, I believe you are right. Those are the tested and approved one but anything that uses MCU should in theory work. Can always give it a try and see what happens. Quote
IronFilm Posted January 11, 2021 Report Posted January 11, 2021 I use an iCON Platform M+ (w D2 Display) myself with an 833, from reading the 8 Series group it seems other non-official may "work" but it depends on your luck as to how well it "works" and how many quirks you'll have to put up with. If you just simply want a relatively predictable and solid control surface, then get the iCON Platform M+ (or the SX-LC8+ if you really want it as compact as possible, or a CL12 if you've already got one, or ideally the CL16 if you've got the cash). Quote
Xavier Prat Posted April 6, 2021 Report Posted April 6, 2021 I would be VERY curious to know because it's still Mackie universal protocol and also it's the same brand as the other already supported controllers, in addition to that if the X-touch is supported I don't see why the Icon pro wouldn't be as it has the same layout of buttons and whatnot so on paper that looks promising did anyone actually tried it out ? Quote
