PCMsoundie Posted February 18, 2022 Report Posted February 18, 2022 Has anyone tried a few yards of thick fake fur on cardboard instead of furniture blankets for a highly reverberant acoustic space? Half Yard Shaggy Faux Fur Fabric Synthetic Plush Craft Patch Sewing Fur Cuts FabricLA-Shaggy-Faux-Fake-Fabric Long Pile Shaggy Faux Fur Squares Fabric Fuzzy Material Cuts Patches Craft DIY Supply Costume Decoration Even when having to put up a 2 wall space for a quick voiceover. Not just walls but say in a bathroom has anyone tried scraps of this fake fur on the floor? Did it help anymore than say a furniture packing blanket on the ground or clamped to the top of the shower curtain loop? Quote
TVPostSound Posted February 18, 2022 Report Posted February 18, 2022 That just won't work. Only high frequency verb might be minimized, but in the voice fundamental frequencies between 150 and 300 will still sound like a bathroom. Quote
PCMsoundie Posted February 18, 2022 Author Report Posted February 18, 2022 46 minutes ago, TVPostSound said: That just won't work. Only high frequency verb might be minimized, but in the voice fundamental frequencies between 150 and 300 will still sound like a bathroom. Would a Owens Corning 703 acoustic insulation, also called rigid fiberglass covered with some thick fake fur on one side be better in a bathroom since they absorb? Quote
Shastapete Posted February 18, 2022 Report Posted February 18, 2022 703 is excellent by itself for acoustic room control. Why are you hung up on fake fur? I wouldn't go near it unless it's an aesthetic choice – useless for sound control Quote
Dalton Patterson Posted February 18, 2022 Report Posted February 18, 2022 Rock wool… All’s I’m sayin. Quote
The Documentary Sound Guy Posted February 18, 2022 Report Posted February 18, 2022 To reinforce what others have said ... you want thickness and mass, not fake fur. We use fake fur on our zeppelins because the hairs cut wind by slowing the airflow down while staying (somewhat) acoustically transparent. Which is to say, they eliminate the source of the unwanted wind noise without affecting the rest of the sound. When treating a room acoustically transparent is the opposite of what you want. You need something that will block and/or absorb noise, not let it through. Fur for cutting reverb might look effective, but it won't do much, especially at lower frequencies. Quote
VASI Posted February 20, 2022 Report Posted February 20, 2022 On 2/18/2022 at 10:44 PM, Dalton Patterson said: Rock wool… All’s I’m sayin. Can you explain or post a link? Thank you! Vasileios A. Quote
Shastapete Posted February 20, 2022 Report Posted February 20, 2022 3 minutes ago, VASI said: Can you explain or post a link? Rockwool is an insulation company. Safe'n'sound is their acoustic insulation product. https://www.rockwool.com/north-america/products-and-applications/products/safensound/?selectedCat=safensound® downloads Owens Corning 703 (without any facing) is another very effective acoustic insulation. https://www.owenscorning.com/en-us/insulation/products/700-series-fiberglas-insulation 703 does slightly better at stoping sound transmission overall, but it is more expensive. Frequency 125 250 500 1000 2000 4000 Overall 3" OC703 0.31 1.07 1.26 1.15 1.05 0.97 1.15 3" RW SnS 0.52 0.96 1.18 1.07 1.05 1.05 1.05 Quote
TVPostSound Posted February 20, 2022 Report Posted February 20, 2022 On 2/18/2022 at 10:08 AM, PCMsoundie said: Would a Owens Corning 703 acoustic insulation, also called rigid fiberglass covered with some thick fake fur on one side be better in a bathroom since they absorb? Yes, forget the fur. Cover the 703 with batting, the kind used in quilts. Mainly to keep fiberglass from shedding in the air. Rockwool is also a great product, but get what's available locally. Start with corners, you might be amazed with just that. Quote
VASI Posted February 20, 2022 Report Posted February 20, 2022 2 hours ago, Shastapete said: Rockwool is an insulation company. Safe'n'sound is their acoustic insulation product. https://www.rockwool.com/north-america/products-and-applications/products/safensound/?selectedCat=safensound® downloads Owens Corning 703 (without any facing) is another very effective acoustic insulation. https://www.owenscorning.com/en-us/insulation/products/700-series-fiberglas-insulation 703 does slightly better at stoping sound transmission overall, but it is more expensive. Frequency 125 250 500 1000 2000 4000 Overall 3" OC703 0.31 1.07 1.26 1.15 1.05 0.97 1.15 3" RW SnS 0.52 0.96 1.18 1.07 1.05 1.05 1.05 Thank you, Peter! Quote
Dalton Patterson Posted February 21, 2022 Report Posted February 21, 2022 5 hours ago, Shastapete said: Rockwool is an insulation company. Safe'n'sound is their acoustic insulation product. https://www.rockwool.com/north-america/products-and-applications/products/safensound/?selectedCat=safensound® downloads Your making it sound like I’m wrong. Rockwool is made of rocks heated to become lava-like liquid. I cut my teeth on theater construction. Quote
Shastapete Posted February 21, 2022 Report Posted February 21, 2022 15 hours ago, Dalton Patterson said: Your making it sound like I’m wrong. Rockwool is made of rocks heated to become lava-like liquid. I cut my teeth on theater construction. No, I was agreeing with you... VASI asked for further explanation, so I provided some context. I've built around a dozen studios using both Rockwool and OC703 and agree that it is a great product. OC703 is more structurally rigid and can be wrapped in fabric and hung on a wall by itself. Rockwool is a bit fluffier, still holds its shape, but to be used as acoustic paneling, then it needs a structural frame. So in my experience, for making acoustic panels, OC703 wins, it also is a bit better at controlling the 250 to 1000hz range where voice intelligibility comes from. I prefer to use rockwool for built in acoustic treatment – where you have studs to provide the support to keep it in place. It is also fantastic for bass traps (because it is better at frequencies below 200hz) However, since it is less rigid and can be compressed when building a big stack in the corner you'll need some thin shelves fixed to the walls to transfer the weight – I like 1/4" ply with a number of large holes cut in it every 24" or so for this Quote
Dalton Patterson Posted February 21, 2022 Report Posted February 21, 2022 4 hours ago, Shastapete said: No, I was agreeing with you... VASI asked for further explanation, so I provided some context. Please excuse me, humble apology. Quote
