Eric Lau Posted January 19 Report Share Posted January 19 What is the audio cables for AES? Need to use like 110obm high quality cable, cannot use the normal audio cable? I use on Lectrosonics DSR4 , SRB with AES plate, and install in Lectrosonics Octopack with audio cable to Sound Devices Scorpio. Quote Link to comment Share on other sites More sharing options...
Matthew Steel Posted January 19 Report Share Posted January 19 AES is specified to use 110 ohm cable, but in my experience normal mic cable will work just fine for shorter runs. For example, I've used a 12 foot Canare star quad mic cable in a pinch on multiple occasions. I have also used regular XLR to RCA adapters to go between AES and SPDIF because the specifications are close enough. Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted January 19 Report Share Posted January 19 I have gotten away with normal XLR mic cable or even 75 ohm video cables (with BNCs) for really short jumps. For an upcoming show where I need runs from 10-20 ft I'm going to use 110 ohm XLR cables spec'ed for AES audio use. Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted January 20 Report Share Posted January 20 For short cables it does not matter the kind of cable. Quote Link to comment Share on other sites More sharing options...
tourtelot Posted January 20 Report Share Posted January 20 12 hours ago, RadoStefanov said: For short cables it does not matter the kind of cable. This! 25-footers for me with no problem I could see or measure. I use 110ohm because it's "correct", but that's just me. D. Quote Link to comment Share on other sites More sharing options...
