VASI Posted July 29, 2022 Report Posted July 29, 2022 Hi all, Schoeps has been announcement the CMC 1 KV microphone amplifier with magnetic back. Full details can be found here: https://schoeps.de/en/products/colette/microphone-amplifiers/cmc-1-kv.html Quote
Trey LaCroix CAS Posted July 29, 2022 Report Posted July 29, 2022 I’m salivating 🤤 Do you think there would be a way to rig a metal plate on the car headliners so you could just pop these babies on and adjust to your hearts content? Quote
tourtelot Posted July 29, 2022 Report Posted July 29, 2022 Have props or transpo carefully slit the visor and slide a thin piece of sheet steel inside. Glue it closed. Done. On a picture that has a "hero" car? Brilliant. D. Quote
Mungo Posted July 31, 2022 Report Posted July 31, 2022 Cables beside XLR only available for ZMT and A10? So you need a transmitter that provides real 48V Phantom power to make it work. Anyway you can use an UMP box or adequate with other transmitters. We are used to this. Or a plug on tx. Quote
