Pleasesendmemoney Posted August 24, 2024 Report Posted August 24, 2024 I have a Sony ECM77B lav mic with the standard XLR connector. My question is……is it possible to physically cut that XLR connector off and solder on a 3.5mm locked connector? And obviously still have it work properly. Quote
Tim Norris Posted August 24, 2024 Report Posted August 24, 2024 I do this (have it done for me) but with a TA5 for 'Lectro. Cheers, Tim Quote
dsound Posted August 25, 2024 Report Posted August 25, 2024 Hi Tim, Can you share the pin wire assignment for the TA5 soldering. Thanks! Quote
TVPostSound Posted August 25, 2024 Report Posted August 25, 2024 I have an ECM77B. Why not put a battery in the preamp shell, and use a female XLR to 1/8" locking? https://www.amazon.com/Sennheiser-004840-CL-2/dp/B003LRYUBE/ref=asc_df_B003LRYUBE/?tag=hyprod-20&linkCode=df0&hvadid=693544921083&hvpos=&hvnetw=g&hvrand=17931085367693043547&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9190171&hvtargid=pla-633362881917&psc=1&mcid=b1eeffbbe6ec34ad86ff1f751896707f&gad_source=1#customerReviews Quote
Pleasesendmemoney Posted August 25, 2024 Author Report Posted August 25, 2024 9 hours ago, Tim Norris said: I do this (have it done for me) but with a TA5 for 'Lectro. Cheers, Tim Tim……who did it for you? Was is someone available to us or is it a friend? I can solder. If it’s possible could you point in the right direction as how to do the conversion? Thank you very much. Quote
Pleasesendmemoney Posted August 25, 2024 Author Report Posted August 25, 2024 12 hours ago, TVPostSound said: I have an ECM77B. Why not put a battery in the preamp shell, and use a female XLR to 1/8" locking? https://www.amazon.com/Sennheiser-004840-CL-2/dp/B003LRYUBE/ref=asc_df_B003LRYUBE/?tag=hyprod-20&linkCode=df0&hvadid=693544921083&hvpos=&hvnetw=g&hvrand=17931085367693043547&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9190171&hvtargid=pla-633362881917&psc=1&mcid=b1eeffbbe6ec34ad86ff1f751896707f&gad_source=1#customerReviews My goal here is to use the mic with a Tentacle Track E recorder which is very tiny. The part you mentioned would make an already huge XLR connection that much bigger. I need minimalist so I’m going for small, unobtrusive. Great idea for other applications but not my use case. Thank you very much for the idea. I think it will help folks who need that connection. Quote
Tim Norris Posted August 26, 2024 Report Posted August 26, 2024 On 8/24/2024 at 11:31 PM, dsound said: Hi Tim, Can you share the pin wire assignment for the TA5 soldering. Thanks! I can't, because I do not do it myself. I believe wiring instructions come with all 'Lectro transmitters. Cheers, Tim Quote
borjam Posted August 26, 2024 Report Posted August 26, 2024 I found service manuals for the ECM77 microphones (and others) https://www.manualslib.com/download/2989956/Sony-Ecm-44bmp.html According to a note it includes ECM-77B in an appendix. The diagrams include cable colors, so I guess it will be possible. Note: the capsule assembly includes some electronics, a FET transistor. I would check whether the part numbers are the same for the BMP/B variants. Quote
Pleasesendmemoney Posted August 27, 2024 Author Report Posted August 27, 2024 11 hours ago, borjam said: I found service manuals for the ECM77 microphones (and others) https://www.manualslib.com/download/2989956/Sony-Ecm-44bmp.html According to a note it includes ECM-77B in an appendix. The diagrams include cable colors, so I guess it will be possible. Note: the capsule assembly includes some electronics, a FET transistor. I would check whether the part numbers are the same for the BMP/B variants. Great find. Thank you very much. It’s a bit over my head technically. It seems like I could, in fact, just cut the wire off the large end where the battery goes and solder the wires to a 3.5mm TRS Locking Connector. But I’m not 100% sure about that. Quote
Pleasesendmemoney Posted September 7, 2024 Author Report Posted September 7, 2024 I’m just not 100% sure about cutting the wire and soldering it to a 3.5mm connection. My other option is to sell it. Hmmmm…… Quote
Rick Reineke Posted September 8, 2024 Report Posted September 8, 2024 I had a ECM 77 which which I converted to use with a Tx, though it was long ago and I do it recall the pin assignment. I also put a compatible jack on the XLR power supply's cable, so I could still use it in a hard wired scenario. Quote
Pleasesendmemoney Posted September 9, 2024 Author Report Posted September 9, 2024 On 9/8/2024 at 11:01 AM, Rick Reineke said: I had a ECM 77 which which I converted to use with a Tx, though it was long ago and I do it recall the pin assignment. I also put a compatible jack on the XLR power supply's cable, so I could still use it in a hard wired scenario. Rick......please excuse my lack of knowledge on these matters but.....what did you mean when said "to use with a Tx"? What is a Tx? Quote
Rick Reineke Posted September 10, 2024 Report Posted September 10, 2024 Tx is an abbreviation for "transmitter" Rx is an abbreviation for "receiver" Quote
