Jack Norflus Posted April 1, 2012 Report Share Posted April 1, 2012 Version 2.95 has been posted today. The two main thing 2.95 has is it adds is mix 8 support and it fixes the bug in which Nomad won't continuous mirror the first take after a power cycle. Quote Link to comment Share on other sites More sharing options...
Clacker Posted April 1, 2012 Report Share Posted April 1, 2012 For those of us doing doc work, run and gun with long takes, I'm super happy for the latter mirror fix! (And I'm assuming mix-8's are about to be backordered for months? Quote Link to comment Share on other sites More sharing options...
Chase Yeremian Posted April 1, 2012 Report Share Posted April 1, 2012 Mix 8 will connect to Nomad via DB15 connector? Quote Link to comment Share on other sites More sharing options...
glenn Posted April 1, 2012 Report Share Posted April 1, 2012 Mix 8 connects to a USB style connector on Nomad and a DB9 on the Mix 8. Mix 8 comes with a interface cable for either Deva/Fusion or Nomad. Additional interface cables may be purchased from Zaxcom. We have been able to also provide some MIX12 functionality. Mix12 faders, trim pots and input meters are supported. This will allow anyone to use the Nomad as a Deva or Fusion backup with MIX8 or Limited MIX12 support in a pinch. Glenn Quote Link to comment Share on other sites More sharing options...
ramallo Posted April 1, 2012 Report Share Posted April 1, 2012 Hello, MIX 8 can it work with all Nomads? Cheers Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted April 1, 2012 Author Report Share Posted April 1, 2012 Yes all versions of Nomad will work. Quote Link to comment Share on other sites More sharing options...
Chase Yeremian Posted April 1, 2012 Report Share Posted April 1, 2012 Mix 8 connects to a USB style connector on Nomad and a DB9 on the Mix 8. Mix 8 comes with a interface cable for either Deva/Fusion or Nomad. Additional interface cables may be purchased from Zaxcom. We have been able to also provide some MIX12 functionality. Mix12 faders, trim pots and input meters are supported. This will allow anyone to use the Nomad as a Deva or Fusion backup with MIX8 or Limited MIX12 support in a pinch. Glenn Fantastic! Quote Link to comment Share on other sites More sharing options...
ramallo Posted April 1, 2012 Report Share Posted April 1, 2012 Yes all versions of Nomad will work. My unit shows: "MIX8 is not supported on this hardware" Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted April 1, 2012 Author Report Share Posted April 1, 2012 My unit shows: "MIX8 is not supported on this hardware" Some Nomads need to have a chip reprogrammed to support mix-8. This reprogram is not able to be done via a software update. If you get that message you need to contact Zaxcom regarding getting your chip updated. Quote Link to comment Share on other sites More sharing options...
Christian Spaeth Posted April 1, 2012 Report Share Posted April 1, 2012 where could that message be found? on startup? Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted April 1, 2012 Author Report Share Posted April 1, 2012 From the main menu go to mode - scroll down to mix 8 turn it on. Quote Link to comment Share on other sites More sharing options...
paul55 Posted April 1, 2012 Report Share Posted April 1, 2012 where can I download the lastest Nomad Software? their website has v 2.89 only Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted April 1, 2012 Report Share Posted April 1, 2012 where could that message be found? on startup? I think you have to buy a Mix 8 to see it. Two grand is a lot to pay just to be able to see a message. But, then, this is April first. Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted April 1, 2012 Author Report Share Posted April 1, 2012 where can I download the lastest Nomad Software? their website has v 2.89 only The web site currently only has 2.89 you need to go to the forum to get 2.95. Quote Link to comment Share on other sites More sharing options...
