Jacob Gustavsson Posted March 6, 2014 Report Posted March 6, 2014 I just noticed that Marenius has come out with a new mixer/recorder model (not sure how long ago). This time it records four inputs as well as a L/R mix. Read about it here: http://www.marenius.se/audiodesign/mm-4240.htm Manual: http://www.marenius.se/pdf/MM4240%20manual.pdf Quote
Freeheel Posted March 6, 2014 Report Posted March 6, 2014 Hmmm, list price seems rather expensive for the current market. Are SD and Zaxcom THAT expensive in Sweden that this would be competitive? And some weird connectors, like SVHS for S/PDIF out? That's truly odd. And 4 "C" batteries. And all connectors out the bottom. I'm feeling like I am not part of their target market... Cheers, Brent Calkin Quote
Christian Spaeth Posted March 6, 2014 Report Posted March 6, 2014 kind of reminds my of my old R-44. Quote
MartinKarlsson Posted April 3, 2014 Report Posted April 3, 2014 The MM-4240 is "almost" released, the documents in the link are for a pre-release, and the final release will be in April 2014. The new documents will be posted on www.marenius.se soon. Regarding Freeheels comment: The mixer comes with a miniDIN-4 to 2xBNC breakout cable. There are acyually six C (R14) batteries, the chemistry is up to the user. The custom made Porta Brace carrying case solves the cable connectors on the back quite efficient. The Mixer is developed together with Eric Spitzer-Marlyn. /Martin Karlsson, Marenius Elektronikutveckling. Quote
soundtrane Posted April 3, 2014 Report Posted April 3, 2014 some immediate reactions: DC 6-15V - should be up to 18V to accomodate Li-Ion packs DC input should be locking connector 'C' size battery - each weighs 70 grams, so 6 x7 = 420 grams. quite a lot to add to a mixer that is 1300 grams. SD card holder has no lid - card can pop out mini-DIN for digital outputs (2) - strange "Headphone volume / Power switch (outer potentiometer) Controls the volume for the headphone jack, at full CCW the unit is shut down. To POWER ON the device turn the knob CW." This is did not get... Quote
Jacob Gustavsson Posted April 3, 2014 Author Report Posted April 3, 2014 some immediate reactions: DC 6-15V - should be up to 18V to accomodate Li-Ion packs DC input should be locking connector 'C' size battery - each weighs 70 grams, so 6 x7 = 420 grams. quite a lot to add to a mixer that is 1300 grams. SD card holder has no lid - card can pop out mini-DIN for digital outputs (2) - strange "Headphone volume / Power switch (outer potentiometer) Controls the volume for the headphone jack, at full CCW the unit is shut down. To POWER ON the device turn the knob CW." This is did not get... In other words, a fair bit to worry about. Quote
Richard Thomas Posted April 3, 2014 Report Posted April 3, 2014 Hmmm, list price seems rather expensive for the current market. Are SD and Zaxcom THAT expensive in Sweden that this would be competitive? Yes (or they are in the UK), this is maybe a bit more expensive than a Roland R-88 Quote
Nick Ray Harris Posted April 3, 2014 Report Posted April 3, 2014 Now I can swap batteries between my recorder and my old boombox! Quote
MartinKarlsson Posted April 4, 2014 Report Posted April 4, 2014 The weight of the mixer is 1300 grams with batteries included. Quote
MartinKarlsson Posted October 2, 2014 Report Posted October 2, 2014 some immediate reactions: DC 6-15V - should be up to 18V to accomodate Li-Ion packs DC input should be locking connector 'C' size battery - each weighs 70 grams, so 6 x7 = 420 grams. quite a lot to add to a mixer that is 1300 grams. SD card holder has no lid - card can pop out mini-DIN for digital outputs (2) - strange "Headphone volume / Power switch (outer potentiometer) Controls the volume for the headphone jack, at full CCW the unit is shut down. To POWER ON the device turn the knob CW." This is did not get... The MM-4240 accepts NP-1 batteries, we do supply a NP-1 connector cable with a locking connector. The production version of the MM-4240 is equipped with a locking DC connector. The power ON/OFF function is integrated in the headphone potentiometer and has a distinct mechanical click which makes it hard to accidently turn of the mixer. The solution also protects your ears in some manner. Quote
