Jeff Wexler Posted December 4, 2014 Report Posted December 4, 2014 For those using Movie Slate for sound reports, what do you do when there is no viable WiFi network to email the .pdf sound report? I have worked out a few ways of file transfers and so forth, and obviously if someone needs a report emailed to them they may just have to wait until email is possible. If a printer is available I know there are ways to print directly from the iPad I've just never tried it myself. Quote
Peter Posted December 5, 2014 Report Posted December 5, 2014 Hi Jeff although I normally email when I get home couldn't you set up a personal hotspot with your iphone and send it? Quote
Wandering Ear Posted December 5, 2014 Report Posted December 5, 2014 I have found that production usually has a mobile hot spot for the ad's / PM's to work off of at base camp. I have used that to email reports when on location, or I tell production it has to wait until I have access. Quote
jason porter Posted December 5, 2014 Report Posted December 5, 2014 Do this! Hi Jeff although I normally email when I get home couldn't you set up a personal hotspot with your iphone and send it? Quote
Mark LeBlanc Posted December 5, 2014 Report Posted December 5, 2014 Also use Personal Hotspot, had issues thinking it got sent but didn't so I started including myself in the email list to double check that the email actually got sent.. Quote
Wandering Ear Posted December 5, 2014 Report Posted December 5, 2014 Also use Personal Hotspot, had issues thinking it got sent but didn't so I started including myself in the email list to double check that the email actually got sent.. I always include myself on the email list for this reason. I bcc myself when sending invoices too to verify they went through. Quote
Jeff Wexler Posted December 5, 2014 Author Report Posted December 5, 2014 Sorry, I actually stated my question incorrectly by only mentioning WiFi. I have a hot spot, I have an iPhone, my iPad is on the network. What I really meant to say is when there is NO network available, WiFi, cellular, etc. (no cellular service from any carrier out in the sticks), what are the various ways you could get the .pdf report out of the iPad and to a printer, for example. Quote
ProSound Posted December 5, 2014 Report Posted December 5, 2014 get an Apple Air Print compatible printer Quote
Jeff Wexler Posted December 5, 2014 Author Report Posted December 5, 2014 Thank you, Whitney, I think this may be the answer. Quote
Wandering Ear Posted December 5, 2014 Report Posted December 5, 2014 I haven't tried this, and can't until tomorrow cause I don't have a USB cable for my ipad with me, but you might be able to retrieve the sound report through iTunes file sharing. In the MS settings, check "Email & Archive", this way a zipped sound report is saved to your ipad. Then iTunes should be able to copy that zip file onto a computer, which would allow you to distribute it digitally to production, print it, copy to a usb stick, etc. I can test it tomorrow after I wrap. Quote
Diego Sanchez Posted December 5, 2014 Report Posted December 5, 2014 Hi Jeff, you can use one of this http://www.kingston.com/us/wireless/wireless_readers#mlw221 and plug the final card and put the report on it or a separate SD card. Quote
Jim Hawkins Posted December 6, 2014 Report Posted December 6, 2014 Hi Jeff, When I first got Movie Slate, I thought that would be required, and I bought an Air Print printer. That's when I learned that all Air Print printers aren't created equally. The first one required being connected to a net with WiFi, and I couldn't print directly to the printer from the iPad without both being on a network. This was not what I'd expected, and the next weekend when I got off work, I took my iPad to Best Buy and found one I could print to directly. I ended up with an HP ENVY 4500. Best Wishes. Quote
RPSharman Posted December 6, 2014 Report Posted December 6, 2014 Jeff, On "Justifed", when I finshed last season for Brett, I just sent it when I got home. When shooting in the "sticks", I don't believe anyone minds getting it a bit later. Robert Quote
