docsound Posted March 25, 2020 Report Posted March 25, 2020 Hi folks, I'm new to the forum and hope I'm right here with my question: I'm a documentary filmmaker/director who is doing more and more his own sound. I've experiences with a 788T and a 633 and was using the sound report feature. But while shooting I always wanted to add a marker to the exact TC in that moment, so that I'm able to review this marker later – after a long shooting day with long takes – and add notes to all the markers. This notes would be very helpful for postproduction. I guess I'm not using the full potential of todays mixers/recorders. But maybe some of you guys are owning mixers/recorders and have experiences with more detailed metadata in a doc/run-n-gun typ scenario. Thanks! Quote
sonicfruit Posted March 25, 2020 Report Posted March 25, 2020 Try hitting the <Record> button on the fly, while recording. I think that drops markers or creates a new file or cue point. be well kathryn k Quote
Trey LaCroix CAS Posted April 7, 2020 Report Posted April 7, 2020 I recently did a doc where we rolled all the time unless we were traveling. I hit record every time we went to a new setup in order to create some kind of marker and the editor said it worked "fine" and "not to difficult." High praise from an editor! Quote
Mattias Larsen Posted May 18, 2020 Report Posted May 18, 2020 On the mixpres there is a marker option. It is a bit clunky to review and adjust. Not sure if it shows up on the sound report but shows up as named markers in some audio programs. So depending on workflow it could be something. Quote
Rick Reineke Posted May 18, 2020 Report Posted May 18, 2020 Makers and regions generally show in the DAW timeline. Quote
docsound Posted July 12, 2020 Author Report Posted July 12, 2020 Thanks everybody! Maybe Ambient is currently developing what I was looking for: https://logger.ambient.de Quote
Fred Salles Posted July 18, 2020 Report Posted July 18, 2020 On 7/12/2020 at 5:44 PM, docsound said: Maybe Ambient is currently developing what I was looking for: https://logger.ambient.de I don't think that is creating several markers on a single take. I guess it is just using the "circle take" metadata, which is the only metadata you can add on the fly to mark a take as good one afaik. On the sound devices 6 series i used wingman app and press @ for marking a take. On the 7 series it was done in the FILE: view take list menu (you could even set it as bad take). If you really need to mark during takes I guess you have to used some of the continuity orientated app working with TC and wifi, like the one by Ambient (but you need to use their Lockit): http://lockitnetwork.com/apps/ Otherwise, a Tentacle is cheaper and you can read the TC on your ipad via bluethooth, and I just read on their webpage that the app Movie slate is compatible. I do not know it but maybe check it out: https://www.movie-slate.com/ Quote
IronFilm Posted August 17, 2020 Report Posted August 17, 2020 On 7/19/2020 at 10:13 AM, Fred Salles said: Otherwise, a Tentacle is cheaper and you can read the TC on your ipad via bluethooth, and I just read on their webpage that the app Movie slate is compatible. I do not know it but maybe check it out: https://www.movie-slate.com/ I think the Movie Slate App has a Script Supervisor option which allows the timecode to automatically be noted next to the notes as you write them into the app. Quote
