foliver Posted March 16, 2021 Report Posted March 16, 2021 Hi all. In my lav case, I've some mke2's with bent cables. Cables are clean, capsules too, but the cable is not straight, and is impossible to use them with light garment....at least for me, I prefer to go with another ones. But for some situations, I would like to have a straight mke2.. Someone knows if they are a magic thing to do, to help them to find a straight line? I've tested with coconut oil, and despite to clean, and soften a little bit the surface...... Any tip? Please avoid the " buy a new one" answers. Thanks! Quote
Ben B Posted March 16, 2021 Report Posted March 16, 2021 Try blowing hot air on it, with a hairdryer for example, while laying the cable straight and flat. It should warm up the cable jacket and soften the rubber. Let it cool down flat and straight and it should get rid of all the kinks and twists. I do this with XLR cable and it works pretty good. Quote
foliver Posted March 16, 2021 Author Report Posted March 16, 2021 Hi Ben, I’ll try that with one mke2 red dot that I have for car exhausts. thanks for your idea Quote
Rick Reineke Posted March 16, 2021 Report Posted March 16, 2021 I weight down one end of the mic/cable and hang in a warm environment ( preferably above room temp, like over a radiator or heating duct) for a few days or longer. Naturally the weight and heat should not be excessive. I do this with all kinds of cables. Quote
David Waelder Posted March 16, 2021 Report Posted March 16, 2021 I used to cover Marc Gilmartin on double-up days. He had a cable hanging bracket attached to his cart. I don't know if this is the exact model he used but it's the idea: https://www.pacrad.com/middle-atlantic-equipment-accessories-claw.html Ordinarily, this is used to manage the pigtails that might otherwise clutter a sound studio. Marc used it to hang his lavalier microphones. He would either put a collar on the cable or attach a strip to make the slot more narrow. A cable that was particularly kinky might have a weight attached at the bottom to help stretch things out. He would routinely store lav cables this way and they tended to lie straight. Of course, he would pack up the lavs in the normal way when moving locations. David Quote
Izen Ears Posted March 17, 2021 Report Posted March 17, 2021 I have heard leaving cables in the sun in Summer makes em straight again... Quote
Tim Norris Posted March 17, 2021 Report Posted March 17, 2021 17 minutes ago, Izen Ears said: I have heard leaving cables in the sun in Summer makes em straight again... Yep... sunbathing on a nice day off! Quote
foliver Posted March 17, 2021 Author Report Posted March 17, 2021 11 hours ago, David Waelder said: I used to cover Marc Gilmartin on double-up days. He had a cable hanging bracket attached to his cart. I don't know if this is the exact model he used but it's the idea: https://www.pacrad.com/middle-atlantic-equipment-accessories-claw.html Ordinarily, this is used to manage the pigtails that might otherwise clutter a sound studio. Marc used it to hang his lavalier microphones. He would either put a collar on the cable or attach a strip to make the slot more narrow. A cable that was particularly kinky might have a weight attached at the bottom to help stretch things out. He would routinely store lav cables this way and they tended to lie straight. Of course, he would pack up the lavs in the normal way when moving locations. David Nice story, and practice. i remember dpa advice to use coconut oil to keep the lav cables softs. i think May be it can help to do that and sun bath Quote
Conor Posted March 17, 2021 Report Posted March 17, 2021 The problem with the MKE-2s specifically is that they contain 2 braided wires that are used to hold the shape & strengthen the lav cable. Which makes them tough but once they get kinked, it's game over. It's not the rubber shield/casing that's getting twisted & bent, so no amount of hanging/heating/drying/applying oils is going to remedy it. I've yet to find a solution Quote
