JonO Posted August 10, 2011 Report Posted August 10, 2011 My schoeps cmc641 suddenly developed a rattling noise when I swing it side to side- I can only hear it through the headphones- not by putting my ear next to it. It almost sounds like there is a very small grain loose inside it. It was working perfectly fine two days ago. Has anybody had this problem? Oh, and I tried switching cables and inputs. Im pretty sure its the mic. Thanks, Jon Quote
Marc Wielage Posted August 10, 2011 Report Posted August 10, 2011 That's a problem I've never heard. To me, the mikes are so delicate and expensive, you need to talk to the real guys (assuming you're in North America): Redding Audio, Inc. 97 South Main Street - Unit #10 Newtown, CT 06470 (203) 270-1808 info@reddingaudio.com In Germany: Schoeps GmbH Schalltechnik Dr.-Ing. Spitalstraße 20 D-76227 Karlsruhe (Durlach), GERMANY +49 721 943 20-0 http://www.schoeps.de/en/ --Marc W. Quote
jonathan chiles Posted August 10, 2011 Report Posted August 10, 2011 Yes, email Redding or Schoeps in Germany, both respond quickly. I have opened up a CMC body before by loosening the 3 screws at the base which are reverse threaded, possibly its a piece of solder.. but as Mark said, would rather let Redding check it out if you are in USA. Quote
Iacopo Pineschi Posted August 10, 2011 Report Posted August 10, 2011 I once had the same problem, I was shooting outdoors, quite far from the city, so I had to try to fix it by myself. I found out that it was something into the CMC6 that was moving. I first removed the capsule. I discovered that the little screws that keep the CMC6 closed do not hold it like ordinary screws, but they are in the inside, pushing out on the casing, keeping it still. In fact, if you try to screw them clockwise they will keep to go into the mic and they finally will fall into it. If you see one of the screws missing, that's probably what happened and you have just to open the CMC6, take the missing screw and put it in its place. (First post, hello everyone!) Quote
BVS Posted August 10, 2011 Report Posted August 10, 2011 Hi Iacopo... Welcome to our forum and your contribution is appreciated...I think you are probably spot on the money with this...I've had the same thing happen... Enjoy the many views that we have here... BVS Quote
David Levine Posted August 10, 2011 Report Posted August 10, 2011 I had a similar problem with a CMC541. Turned out the mic's XLR was loose. Definitely worth a trip to CT. David Quote
Jeff Wexler Posted August 10, 2011 Report Posted August 10, 2011 Moe Chamberlain had this problem with one of his Schoeps (I think the CMIT) and it did require a trip back to Redding. It wasn't the screws working their way inside but there was something that had come loose and was making a tiny rattling inside. Quote
studiomprd Posted August 10, 2011 Report Posted August 10, 2011 " It was working perfectly fine two days ago. " CRAP happens! Quote
Eric Toline Posted August 10, 2011 Report Posted August 10, 2011 Thanks Rainman :-) Absolutely perfect reply.+1 Eric Quote
studiomprd Posted August 10, 2011 Report Posted August 10, 2011 " Im pretty sure its the mic. " so, you can open it up to see, or send it to be fixed by a pro.... What's it gonna' be ?? Well, do ya' feel lucky?? Quote
JonO Posted August 10, 2011 Author Report Posted August 10, 2011 Thanks for the suggestions - its definitely confined to the preamp as I hear the sound without the mk41 capsule screwed on. It is also only when I quickly swing the mic side to side- I can also replicate by tapping the boom pole. The loose xlr connection is what I am leaning towards. On a job this morning I started to try and loosen the screws to open up the cmc6..then I decided against it (probably wisely ) . I'll take it in and provide an update. Thanks again- this is a great site. -Jon Quote
studiomprd Posted August 10, 2011 Report Posted August 10, 2011 " definitely confined to the preamp " Valuable information resulting from your problem solving techniques. This now points to the small screws holding the XLR insert into the bottom of the preamp module, and these can be gently and firmly tightened with a small screwdriver, at no risk and without opening the microphone Quote
jason porter Posted August 10, 2011 Report Posted August 10, 2011 Those screws can be soft, be careful. Quote
Jeff Wexler Posted August 10, 2011 Report Posted August 10, 2011 " definitely confined to the preamp " This now points to the small screws holding the XLR insert into the bottom of the preamp module, and these can be gently and firmly tightened with a small screwdriver, at no risk and without opening the microphone Not necessarily. In the case of the sound affecting Moe's microphone, there was something inside that was loose... it was not the screws. Quote
studiomprd Posted August 10, 2011 Report Posted August 10, 2011 " something inside that was loose... it was not the screws. " yes, still quite possible, and that might not be a DIY fix, unless you're feelin' lucky.... Well... Quote
Brent Lestage Posted August 10, 2011 Report Posted August 10, 2011 Sounds like there are some others here with some screws loose... Quote
John Blankenship Posted August 10, 2011 Report Posted August 10, 2011 Tim and Brent share the LOTD award for today. Quote
studiomprd Posted August 10, 2011 Report Posted August 10, 2011 Tim = yes, Brent = ?? time for Judge Wopner! Quote
André Boisvert Posted August 10, 2011 Report Posted August 10, 2011 FYI. Schoeps shuts down for the good part of August for summer holidays. Quote
JonO Posted August 11, 2011 Author Report Posted August 11, 2011 FYI. Schoeps shuts down for the good part of August for summer holidays. Yikes! Wish I lived in Germany! I tried tightening the screws and quickly found out how soft the metal is (before I read Jason's post)- and it still rattles....So looks like I'm taking it in to Location Sound tomorrow morning. Quote
studiomprd Posted August 11, 2011 Report Posted August 11, 2011 " shuts down for the good part of August for summer holidays. " Very common in Europe Quote
Glen Trew Posted August 11, 2011 Report Posted August 11, 2011 There is an internal threaded ring that holds the mic head assembly together, and I've known these to loosen and allow the parts inside to "bump" when cuing the mic. This ring has two pin holes, and it is easy to tell if it has loosened. If it is loose, snug it back down and see if the noise goes away. Glen Trew Quote
sdog Posted March 5, 2012 Report Posted March 5, 2012 Hope you guys don't hate me for reviving a dead thread, but I just have to let you know that you've just now saved my butt. The XLR end of my cmc641 was just a little loose. Thought, "Oh, I've got my tiny screwdriver set with me. I'll just tighten this up a bit", noticing the three set screws on the end. Didn't realize the threads were reversed and like lacopo, I "tightened" until the set screw dropped into the inside of the body. This thread (forum thread, not set screw thread) made me brave enough to loosen everything up, slip the end off, dig out and reset the set screw and "bam", I'm good as new. I was dreading trying to figure out how to make do without it, while it languished in CA or Germany. THANKS!! Quote
