Christian Spaeth Posted October 27, 2012 Report Posted October 27, 2012 I am using a mix-8 with my Nomad. I noticed that Nomad reacts to Mix8 fader movements with a small delay. If i pull a fader dowb quickly, it takes about a second until the channel is silent! Has anyone had issues like that with a Mix-8 before? Is it normal? Quote
glenn Posted October 27, 2012 Report Posted October 27, 2012 Nomad fader delay should be unnoticeable. We will check into it. Glenn Quote
Christian Spaeth Posted October 27, 2012 Author Report Posted October 27, 2012 Especially happens when quickly pulling down from +6 or +12 to the bottom. Quote
Jared Detsikas Posted October 27, 2012 Report Posted October 27, 2012 I just got a mix 8 this week and noticed the same thing. Hasn't been an issue for me yet but there's definitely a noticeable delay on fast fades. Running 4.0 on Nomad. Quote
Wandering Ear Posted October 27, 2012 Report Posted October 27, 2012 I've been considering a mix8. I hope the delay is something that can be fixed. Besides the delay, how do you like it? Wandering Ear Quote
RadoStefanov Posted October 27, 2012 Report Posted October 27, 2012 I am buying the mix-8. is the delay only on quick fades? Quote
Michael P Clark Posted October 27, 2012 Report Posted October 27, 2012 This not something that I have noticed, but I'll check again next week. Quote
Christian Spaeth Posted October 28, 2012 Author Report Posted October 28, 2012 The delay on normal fades is barely noticable but there is a delay. When you do quick and long fade-downs the delay is too long and needs to be addressed. Apart from that, working with the Mix-8 and Nomad is fantastic. Mixing just gets so much smoother and easier. I wish the Mix-8 had an on/off switch though, because you have to unplug it from power every time before you power up the Nomad. Quote
Christian Spaeth Posted October 29, 2012 Author Report Posted October 29, 2012 One thing that puts me off is that whenever I quickly want to Disconnect the Mix-8 and use the Nomad faders instead, I have to reboot Nomad. (and re-jam time code to cans subsequently) Otherwise the faders won't be active. Is there a workaround? If not, can this be changed so a power cycle won't be necessary? Quote
Wandering Ear Posted October 29, 2012 Report Posted October 29, 2012 Christian, Thanks for your impressions of the mix 8. You shouldn't have to rejam tc after a reboot. I can see how it'd be annoying to reboot if you need to plug or unplug the mix8. Wandering Ear Quote
Dani Fontrodona Posted October 29, 2012 Report Posted October 29, 2012 Hi Christian, a little off topic, but I am interested in which inputs of Nomad can you control with trims and faders 7 & 8 on mix8, as faders 1 to 6 are supposed to be hardcoded to inputs 1-6, but there is no information regarding these extra faders. Returns 1&2? Thanks Daniel Quote
RadoStefanov Posted October 29, 2012 Report Posted October 29, 2012 Can somebody shoot a little video showing the delay?Thanks Quote
Christian Spaeth Posted October 29, 2012 Author Report Posted October 29, 2012 Kelsey, the reboot is only necessary when you take the Mix-8 off the Nomad. The other way round things work. I hope this can be resolved with a Nomad software update? Daniel, actually I haven't tried, but once I get the time in between takes, I will and report back. If I have more time I will shoot the video with the delay. Quote
Wandering Ear Posted October 30, 2012 Report Posted October 30, 2012 Thanks for the info Christian. Quote
Christian Spaeth Posted October 30, 2012 Author Report Posted October 30, 2012 Confirm that inputs 7 and 8 go to faders 7 and 8. Mix 8 rocks the boat! Quote
Dani Fontrodona Posted October 30, 2012 Report Posted October 30, 2012 Confirm that inputs 7 and 8 go to faders 7 and 8. Mix 8 rocks the boat! Thanks Christian! Anyone using a Mix12 with Nomad 12? wondering about mix faders 9 to 12 Quote
Ezekiel974 Posted October 30, 2012 Report Posted October 30, 2012 mix 12 is not compatible with any nomad. About mix 8 i was wondering, you can't assign whatever you want to the faders ? It all digital why is it not possible ? Quote
Mark Orusa Posted October 30, 2012 Report Posted October 30, 2012 mix 12 is not compatible with any nomad. My understanding is that while Mix 12 is not officially supported it does have limited functionality. Personally, I would love to see full support for it, or better yet a newer, lighter, less power hungry mix surface. Mark O. Quote
rich Posted October 30, 2012 Report Posted October 30, 2012 mix 12 is not compatible with any nomad. About mix 8 i was wondering, you can't assign whatever you want to the faders ? It all digital why is it not possible ? is that new that the mix 12 doesnt work with the nomad? last i had read (some time ago to be honest) was that the mix 12 would work, but with limited functionality. i assumed that only the gains and faders worked, and the faders 9 and 10 controlled inputs 9 and 10. but i was never interested in spending all that money on a mix 12 to do anything sensible like speak to zaxcom and find out for sure. Quote
Dani Fontrodona Posted October 30, 2012 Report Posted October 30, 2012 From Zaxcom forum: "Zaxcom does not officially support Mix-12 use, but you can utilize the faders, trim pots and input meters". And hopefully also keyboard in future (with Nomad 12) Quote
Ezekiel974 Posted October 30, 2012 Report Posted October 30, 2012 sorry, i thought it wasn't compatible at all !! my bad ! Quote
