Jesse Watts Posted January 6, 2016 Report Posted January 6, 2016 So I'm dialing in my new 688 and have found the gain to be very weak on the ext slate mic in. Has anyone else experienced this? I have tried a Sennheiser Me2 condenser and a Sure Dynamic lav on max gain (+36) with the same results. I get good level at mouth distance but not at my typical 2ft ish for slating. Quote
RPSharman Posted January 6, 2016 Report Posted January 6, 2016 I have my 664 on full volume using Shure dynamic mic, and I have to lean into it too. I only use the 664 for car work, so it hasn't presented a huge problem, but I would like a bit more umph there too. Quote
Jesse Watts Posted January 6, 2016 Author Report Posted January 6, 2016 6 hours ago, RPSharman said: I have my 664 on full volume using Shure dynamic mic, and I have to lean into it too. I only use the 664 for car work, so it hasn't presented a huge problem, but I would like a bit more umph there too. Yea I just tested it on my 664 and have a little boost over the 688 but not much. Maybe firmware? It might be a hardware limitation, a silly mistake if that's the case. My 788t has a ton of boost but then again it's routed through a mic pre. Quote
Cujo Posted January 16, 2016 Report Posted January 16, 2016 So I'm dialing in my new 688 and have found the gain to be very weak on the ext slate mic in. Has anyone else experienced this? I have tried a Sennheiser Me2 condenser and a Sure Dynamic lav on max gain (+36) with the same results. I get good level at mouth distance but not at my typical 2ft ish for slating. I love my 688, but yes the external Mic option is terrible IMHO. I am using the standard 7506 with Shure mic and have tested it with other mics to diagnose. The slate Mic has plenty of gain, but comms are so soft that I have to speak very loudly with the Mic right at my lips for the boom op to have a prayer of hearing me. I have tried with and without the CL-12 and with other mics to verify results. Best I can figure is something in the machine. I called and requested a workaround and was assured that my request would get passed along..... We shall see. Sent from my HTCONE using Tapatalk Quote
Philip Perkins Posted January 16, 2016 Report Posted January 16, 2016 My 664's internal mic pretty well sucks (you knew that), deafens boom ops with the switch handling noise. Ext mic has been ok with an old Ant Lion rig, but not with anything else really. The input really needs a powered mic (although only 12v avail), dynamic mics always seem too wimpy unless you eat it while talking. I used to have a weird brand-x powered lav that was an iRiver player accessory, that actually worked pretty well (until I broke it). Other lavs, incl cheapo ones powered by a button battery, don't make enough poop at all. If someone has a suggestion of a 12v powered small mic that that input likes I'd love to hear about it. Quote
Phil Rosati Posted January 16, 2016 Report Posted January 16, 2016 I've been running a Denecke 48v phantom power box with a Senn 416 plugged into it just to get enough level with the gain maxed. It would be awesome if this were a firmware fix. Quote
TomBoisseau Posted January 16, 2016 Report Posted January 16, 2016 The Remote Audio headset (model BCSHSDBC) has worked reasonably well for me in conjunction with the Boom Cable System and the 664. I have yet to try it however with the 688. Yes, I do need to keep the mic close to my mouth, but being that it's mounted on the headset I don't see that as a problem. Are you guys saying that the com mic gain on the 688 is LESS than that of the 664? That might present a challenge, because while it is satisfactory with the 664, it does require that the gain be set to maximum. http://www.trewaudio.com/product/remote-audio-bcshsdbc/ Tom Quote
Jesse Watts Posted January 31, 2016 Author Report Posted January 31, 2016 On 1/16/2016 at 8:46 PM, TomBoisseau said: The Remote Audio headset (model BCSHSDBC) has worked reasonably well for me in conjunction with the Boom Cable System and the 664. I have yet to try it however with the 688. Yes, I do need to keep the mic close to my mouth, but being that it's mounted on the headset I don't see that as a problem. Are you guys saying that the com mic gain on the 688 is LESS than that of the 664? That might present a challenge, because while it is satisfactory with the 664, it does require that the gain be set to maximum. http://www.trewaudio.com/product/remote-audio-bcshsdbc/ Tom Tom, Yea, its considerably lower than my 664 and my 633. I called them and they said they would look into it. Maybe a few more owners should let them know about it. Quote
Dave Rainey Posted August 6, 2019 Report Posted August 6, 2019 any updates or fixes here on this issue? thx! Quote
Derek H Posted August 8, 2019 Report Posted August 8, 2019 Shure makes a line of gooseneck podium mics that work on 12 volt phantom that sound good with the 6-series. Just be careful of feedback if you’re using a speaker between takes. Quote
Tales Manfrinato Posted August 10, 2019 Report Posted August 10, 2019 @Derek H is that CVG series? --- 11 to 52V . Have you ever tried them? Quote
Dave Rainey Posted August 19, 2019 Report Posted August 19, 2019 are you using the ones with the base? or plugging directly into your recorder? photos? Quote
Derek H Posted August 19, 2019 Report Posted August 19, 2019 No I just Velcro and or zip tie it wherever it’s needed Quote
Johnny Karlsson Posted August 19, 2019 Report Posted August 19, 2019 I'm not suggesting anyone should go invest $400 on a Com-Mic, but if you like myself already have these in your kit: a Peter Engh Omnigoose via an Ambient Eumel sounds great with plenty of gain on the 664. Also; (sorry if too obvious) on the 664, there is Slate/Com mic gain, and a separate menu item control for Com Send gain - try boosting both and see if that helps. Quote
