Hi hi!
I was wondering about this Chest Straps, has anyone used it before? Do you girls/guys recommended it?It is very appealing for the right circumstances right? instead of using tape or clip? What do you think?
When I first bought the chest strap, I thought it would be a convenient way to reduce rustle noise on a hairy chest.  It does that a bit, but there are usually better ways to deal with it.  What I use it for primarily now is hiding the mic cable, which it does a very good job at.
Yes, I use it primarily on sweaty guys who only wear a t-shirt, so it can’t easily be taped anywhere. For that it works great. It’s invisible. I does reduce hair rustle a bit, but I don’t think that it’s even claiming to do that.
I have found to use it mostly at male actors. Works well, but not everytime.
Although, I can vouch for that accessory. Most of times you need to be fast, so a great addition to your kit and cheap.
I'd 2nd that its worth having in your kit. It's by no means the go to wiring method but good to have in your back pocket when nothing else is working. Mostly comes in play for hairy or sweaty scenarios...
  • 1 month later...
  • 4 months later...
I once worked with a mixer who's straps were labelled L, XL, XXL, XXXL etc. I had to hide the labelling from body aware actors/actresses, especially if I was using the XXXL. So I don't mind colour codes. I label as 1, 2, 3 etc to represent size.
