Hey Guys,
I often use a pair of NT5's plugged into channels 1 and 2 of my 833 with balanced cables in XY for recording ambiance. I find that they quite often pick up interference from mobiles/radios with beep beep beep data noises.
Has anyone else had this issue? Did you resolve it? Any recommended ambiance mics that don't do this?
Thanks
Are you sure it is the mics? Try star-quad cables, which are especially good for blocking RF. I like Canare's L-4E6S...relatively easy to prepare, solder and a pleasure to work with in hot / cold environments. Canare also has a L-4E5C Mini-Star-Quad if weight /size  is an issue.
In addition to star quad (used in pretty much all my XLR cables), I built a few cables with Neutrik's EMC connectors. "The EMC-XLR Series is a specifically designed version of the XX series to give enhanced RF screening for critical applications in live performance and recording where there are particular problems with radio transmission or mobile phones." https://www.neutrik.us/en-us/neutrik/products/xlr-connectors/xlr-cable-connectors/emc-series?c=audio
How much of a difference does it make? Not sure, but the connectors work fine (and are less janky in the field than a clamp-on ferrite bead, imo).
More than willing to hear from others who disagree...
Star quad cables, jumper pin 1 to XLR shells on both ends.
Some might say this creates a ground loop, but that is only on the case of equipment to equipment.
It doesnt apply to microphones.
Ive been doing my own like this for years.
Label the cables as MIC ON:Y
My experience is that you can't use an NT6 (which is about the same mike as NT5) close to an LTE router. Unusable.
I guess we have to deal with that cause NT5/6 are quite old design from the early 2000s when mobile devices weren't such an issue as now. Even old 416s can't deal with today's RF environment.
  • 2 weeks later...
I'm using starquad cables with neutriks the whole time! I think Mungo is right, it's an old design in a new world and maybe needs chucking!
What XY mics are you guys using that don't have interference?
  • 1 year later...
