borjam
Everything posted by borjam
  1. You can hide a lav, transmitter and antenna inside that promising radome! Even pros (and I mean two friends who are actual experts on RF, one of them worked for Agilent in Santa Rosa and they are university professors) say that RF can be a bit of voodoo now and then. Now, seriously. No metal in the clothing? I mean, a bodice with some metal wires or something similar? Something must be detuning the antenna. Maybe she is sweating a lot and adding some isolating material between the antenna and the clothes might help?
  2. I forgot: An easy source for radome material can be aquarium stores. They use to stock stuff for making aquarium backgrounds. I remember some of it was thick paper with a rock like texture. It would probably pass.
  3. Apologies in advance if my suggestions sound silly! Is the antenna pointing upwards? If it gets too close to the metal necklaces I would try pointing it downwards instead. As for stone walls, what about hiding an antenna and running some cable? You can build a radome with some RF inert material. Even simple paper (there is paper available imitating stone textures) covering the antenna should work.
  4. I have volunteered to be a Guinea pig in the phase III trials for the Curevac vaccine. I haven't been inoculated yet and of course I may get a placebo instead (50% chance).
  5. I think it's an interesting development and I dare to say it will be more widely used than you imagine! I work for an ISP and a couple of years ago a producer (a real one, I mean, not a short feature amateur) approached us for a solution to set up a distribution facility. They were shooting a feature and they wanted a quick way to distribute takes, dailies, stills, exchanging them with audio post, vfx, lab, even the ad agency to make press kits available. Everything. It was also used for final delivery to distribution for a year or so. We set up a high availability storage system with proper security measures connected to our backbone network, and we assisted the producer to create a folder hierarchy together with the different permissions so that vfx only saw the files intended for them, the ad agency only the stills and press kits intended for them, etc. It also implemented hard measures against threats such as ransomware. Not even the producer could actually destroy files unless he personally ordered it to us and we had an authentication protocol in place (only two persons with their phone numbers registered were authorized to order any change, and we called back to the authorized number for verification before attending the request) The system worked, albeit it wasn't perfect mosltly due to being a makeshift solution without the thorough design process it requires. Anyway the consequence was that it required more manual attention than it should. Nothing serious. The main hurdles were: - Common storage systems are not designed with complicated workflow hierarchies in mind. This wasn't a hyped production like, say, Game of Thrones or Lord of the Rings (which means nobody expected a serious effort to steal media), but security must be top notch nonetheless. And fine grained security is very complicated. It demanded some manual attention in order to tune folder permissions. - In order to work smoothly this needs excellent connectivity on set and at the different facilities involved. Of course the vfx, audio post and lab companies (major ones) had knowledgeable technical staff and I had no problem at all in order to interact with them and fine tune stuff in order to maximize file transfer performance. Yet there are challenges due to the fact that the Internet protocols were designed at a time when networks had less than sixty four kilobits per second of bandwidth and, despite having being thoroughly tuned afterwards, reaching 1 Gbps of file transfer throughput can be problematic. Some of the facilities used for the sets had subpar connectivity for example. - After I have mentioned the throughput problems I am sure someone has thought: Ha! bandwidth control stuff in place. No, we do not use it at all. We do not have the boxes nor we intend to purchase any. Yet there are technical limitations inherent to years old technology! - Lack of standards is a major hurdle. You can set up a firewall in front of the storage facility and use encrypted connections, but do every parties involved have each and every secure access tool available and ready? It is complicated to manage. Firewall manufacturers don't focus much on interoperability. - Manual work involved. It was production staff who after the shots uploaded the files, etc. That was time consuming and inefficient. - More manual work. Because the lack of previous design work I remember I always kept an eye on the network activity of that particular server in order to avoid any security troubles. That is possible when it's the first time you set up the service and you have just one customer. Despite the hurdles I think it worked (I recall I should send an email to the producer in order to ask what he felt was lacking although I am sure it was mostly the weak points I have just mentioned). Now, take a platform that solves several of these. Say: - Files are automagically uploaded right after each shot. During a take all the previously captured material is being uploaded invisibly. - Forget about having the right Cisco, Fortinet, Juniper, whatever VPN software properly configured. An end to end encryption facility is used. - The software already implements the needed TCP/IP tuning mechanisms in order to maximize throughput. Also, it can upload several files in parallel, which is the best solution or it can split a large file into smaller chunks and upload them concurrently. That is complicated when a production assistant is uploading files manually. - The software makes it easy to create a permissions hierarchy so that each actor has access to the required resources and no more. So: I haven't checked that service yet but without reading anything but the name and the first post in this thread I am sure I ticked several of the boxes And I forgot: What happens with fire on the set or any other similar threat? How long beteween a shot and backup media moved to a different location? With such a system very little material will be lost.
  6. I would stick to a known good powerbank. The MixPres are power hungry and USB power is non trivial. I was experimenting with using a MixPre as an audio interface for an iPad (to run SMAART tools on it for live sound) and due to the flaky USB power provided by the USB to lightning adapters I had startup problems (it took several attempts to boot!) and when the AA NiMH ran low the MixPre entered a reboot loop. Interestingly, the reboot loop didn't seem to affect the audio flow from the microphone to the iPad. Turns out that the FPGA keeps pumping samples once it's been configured. That was funny
  7. Another time waster spammer.
  8. Thus the Oracle of Deafnos spoke!
  9. Looks like that, I've seen similar on other forums. Probably other posts will contain links to advertisements.
  10. I agree. And it's a shame that many companies are relying on Facebook for customer communication instead of setting their own systems. Of course it's cheaper. It reminds me a bit of the situation with the Flash plugin. I always refused to install it because of critical security and privacy issues and sometimes visiting the websites of pro audio manufacturers without it was a real nightmare. Of course Facebook is worse, their behavior seems to be outright criminal.
  11. Late, but for the record I connected my MixPre-3 to a laboratory power supply measuring consumption depending on the operating options. I found out that Bluetooth is essentially free. After all it's very low bandwidth status updates for the meters and time code, it does not send audio after all. The worst offender is the gorgeous screen that, at the same time, you can see under bright sunlight.
  12. True, but I was thinking about the non linear effects, ie, receiver saturation. In a link with enough interference to cause intermodulation on the receiver the directional antenna may be more beneficial on the receiver, as it will attenuate off axis interference (unless Mr. Murphy makes the powerful interference exactly on axis) And in this particular application there is more bandwith from the "transmitter" to the "receiver" (audio) than the reverse (feedback/control signals from the "receiver" to the "transmitter"). Just from a theoretical point of view As for the 941 MHz band, can you use it for wireless microphones in Europe? I have checked quickly at the current Spanish regulations (and it's more or less the same in all the EU) and except for low power wireless telephones I don't see other applications, but I have just checked on the latest update, more on this later). At least the Spanish regulation mentions the 863 - 865 MHz band for wireless microphones, but preferably non professional applications.
  13. I think some improvement can be expected. For starters, the transmissions won't be symmetrical with more bandwidth being used for audio from the transmitter to the "receiver" compared to the feedback signal sent from the "receiver" back to the transmitter. So, a properly aimed directional antenna would at least help reduce interference on the most critical point. Unless, of course, the worst offender is aligned with the RX and the TX. In that case, miracles don't exist
  14. The 2.4 GHz spectrum is a mess. I would bet for a properly regulated cognitive radio approach on the traditional UHF bands or even TV channels exploiting the fact that the whole band is not busy everywhere. As for the 2.4 GHz antenna, remember that it can be challenging to build a good one. Tolerances are tight and it must have quite a usable bandwidth.
  15. In Germany talk to WiMo. They have a good assortment of antennas and they sell both to hams and professional users. As you can't install an amplifier close to the antenna (the "receiver" in digital systems such as Deity is actually a transceiver) keep the cable as short as possible. Another advantage of Wimo is that they can build a pigtail to your specification and they have a good selection of low loss coax cables. Also bear in mind that a splitter will add losses by itself.
  16. Maybe they have been placing those mystery monolithes around the world
  17. I’ve actually seen something similar working. A friend built a prototype using ultrasonic transducers and beaming an amplitude modulated 40 KHz beam. He considered a product for museums in which statues would “speak”. I thought it offered endless opportunities for pranks. It was rather creepy to hear a voice speaking just behind you, really close, only to turn around and see nobody!
  18. AMD has begun to be a serious threat now, if only. It's funny because the Intel 64 bit instruction set was actually designed by AMD, Intel's option, Itanium (a satirical IT website from the UK called it Itanic) fell into oblivion. So, benchmarks are out and the new ARM processor surpasses even the fastest Intel based laptops Apple is selling. Interesting times, this will be like the Unix workstation wars with cutthroat competition among DEC, Sun, IBM, HP...
  19. It should be trivial to recompile (just tick a box so that it generates a fat binary with Intel and ARM code) if your software is somewhat modern. But I guess Pro Tools has a lot of legacy code written for vacuum tube based processors The same can happen to other pro audio applications such as Digital Performer, etc. First benchmarks are out and the results are indeed impressive. https://www.macrumors.com/2020/11/11/m1-macbook-air-first-benchmark/ My only disappointment and the reason why I think I will still wait for a year is, the Macbook Pro has just two USB-C/TB ports. As for fat binaries, I own a NeXT cube and I remember that back in the day NeXT binaries had four versions bundled: Motorola 68000, Sun SPARC, HP PA/RISC and Intel x86. And after all, Macos X is "NeXTStep NG NT ++++++"
  20. My apologies in that case! Maybe I tend to overreact to the antenophobia nonsense because it irks me so much.
  21. Actually, Quantum Physics shows a somewhat non intuitive property. If a radiation source doesn't have energetic enough photons to cause a non thermal effect, ie, it is non ionizing, no matter how many photons you receive no ionization will happen. Only thermal effects. Remember that the number of photons is the intensity of the radiation. Now, imagine you are in Normandie and you want to throw stones at England. No matter how many stones you throw, none of them will hit the target. This is important because there is no cumulative effect for non ionizing radiation. Using your Wifi, mobile phone and wireless microphones 24x7 does not increase a non existant risk because those photons simply will not break chemical bonds. Of course, if the radiation is very strong you can get a burn, but the low powers of typical applications make it simply impossible. So, it's not that it's negligible. It simply is not. Unless, of course, deletereous effects are proven. I forgot to mention that the Ramazzini study (which was pretty well made I think) failed to show a dose dependent response. That also reinforces the idea that the observed effects were actually statistical artifacts.
  22. Yes but antennas can have quite a high voltage. I have a HF antenna in my balcony. It is a loop antenna with a capacitor rated for 5000 V. And yes, depending on the transmission power voltage across the antenna can reach that value. So, no touch when using it. As I live alone it's not a problem. And yet the most likely cause for their cancers, if it was related to radars even, was the X ray emitted by the vacuum tubes and not the microwaves. Exactly. Not even an order of magnitude higher powers should be a problem. There are lots of kinds of radiation So, I would say. Ionizing radiation (ultraviolet, X or gamma rays or nuclear radiation) is of course dangerous. Visible light, unless you are using a laser, is not dangerous. Infrared? Well, it depends on power. If you don't sleep alone, your partner in bed will be radiating infrared. Of course the power is so low... According to Physics you shouldn't be afraid of the radio transmitters you use. Even walkie talkies with 5 W if you ever use them. Now, if on April 1st Lectrosonics announced a gamma ray based wireless microphone, I would get scared!
  23. I just watched today's Apple's "mass". Pretty interesting, the new processors are really efficient as expected. And they have even lowered prices a bit. Not surprised, as Intel prices their processors as they want holding a virtual monopoly. Interesting times coming, especially with those so called "neural" units tailored for machine learning calculations.
  24. As far as I know, there is no hazard unless the power is really high. Let me elaborate: there are two possible effects of electromagnetic radiation: Thermal and non thermal. The non thermal effects (ionization) require a very high energy photon. The radiation capable of doing that is called ionizing radiation and the ionizing spectrum begins at the ultraviolet wavelengths. Anything below that is strictly thermal. The photons simply don't have enough energy to do things like knocking a single electron from an atom. I know there is a lot of bullshit (sorry about the word but it's true) on the matter. There are lots of fake/misunderstood studies. The best study I have seen, the Ramazzini Study, doesn't prove any harm beyond a couple of statistical artifacts. IF you take those statistical artifacts seriously, in one case it turns out mobile phone radiation would be beneficial, go figure. Now: If mobile phone radiation (or the puny low power microwaves in use nowadays) were dangerous, think that mobile phones are working on the same frequencies former used for television broadcasts which used enormous powers. Cities have been blasted with such high power transmissions for decades. Effects? None. Higher microwave frequencies. Have you ever visited a port? X Band radars transmit around 10 GHz. With power measured in kilowatts, and using pulses (some of the antenophobiac people claim that pulses make radio frequency energy more dangerous). Do people living around ports die en masse? No. Do sailors suffer an unexpected high occurence of cancer? Not that I know, apart from maybe skin cancer in fishermen due to excessive exposure to sun light. There are countless reasons to really doubt that radio frequency at the powers we use it (and even an order of magnitude more powerful) can cause any effect. And if it was dangerous, what about visible light with much more energetic photons? If someone really proved any non thermal effect it would mean a Nobel award in Physics. Because it would tear apart all we know about the interaction between light and matter. (I forgot, I mentioned radars and in another discussion someone wielded a study on cancer cases among radar operators without bothering to read it... True, there was a high incidence on radar operators due to improperly shielded valve electronics leaking X ray which of course is ionizing and very dangerous, but with no relationship to the microwaves transmitted by the antenna which anyway was far far away from the operator).
  25. Old, but. https://vimeo.com/20416868
