Everything posted by Nate C
Just received my order today. Thank you Oliver, they are truly amazing. Look forward to making up some cables with them. Cheers Nate.
They have the regular ZMT but not the Phantom version yet. Or Ross is in trouble with me.
As soon as ZMT3 Phantoms arrive in the country, I'm going that way.
Currently I use a curly cable externally for run and gun work using mono mics. I wrap this around the pole as I would with a straight cable. The cable I use was designed to be used internally on an ambient pole but hey, rules were made to be broken. This is the best option I have found that works for me at the moment.
Not the same wheels that Pascal used but I got a second hand Phil and Teds pram from ebay for $1, that has ten inch wheels with quick release axles for my follow cart.
This is a topic that I often find myself debating. Microphone technology has advanced, as has recording equipment (I'm going to leave pre amps out of the equation) from what my sound brothers and sisters were using in the past. Shooting style and the work flow has become more (unnecessarily) complicated. Some days it feels more like management.
Did you apply the Nickwix to the fur or the underlining? Might try some on one of my old Rycote fluffies. I need to reapply some waterproofing to my Goretex jacket and the garden needs watering. Perfect time to experiment.
I went the control surface route over a Cooper, although I still dream of owning a Cooper. My reasoning was mainly based on size, weight and powering requirements. I drive a Mazda CRX5, not a van so the cart needs to be fairly compact. I also live in a fourth floor walk up apartment, so I need to be able to lug the cart up and down the stairs by myself. Being in an apartment storage is a premium and a control surface takes up less space when not in use. For me these were more important factors then workflow. Best of luck in deciding what fits your needs and Cheers. Nate.
Thanks John, good to know. I'll be going to my local dealer on Monday and will check out the INV-Lite.
Thanks Constantin. I was going to add the new DPA to my OP as they have a similar design regarding a really small preamp. I've ordered an INV6 and some stiffer Lyres to try see if I can make that combination work. Until that arrives I have an INV7HG.
Folks using a Schoeps MiniCMIT with a Rycote Softie or Bumblebee Windkiller what shock mount are you using? I knew this mic is small but I didn't realise just how small until mine arrived today.
I made these up for bra straps. Well they were actually made up for SMa transmitters but as there is very little difference in size they work fine. The holes in it are from being stapled to costume. I believe Sound Guys Solutions have just come out with a clip. Not sure if it's available yet.
Thanks John. Edited.
In regards to being small and light weight, a ZMT3 weighs less then the 3 AA batteries I use to power a 742 and the same as 2 AA to power a Lectro HM. I assume the ZMT3 weighs the same or incredibly close to a ZMT3 PH. I'll be adding one to my kit for bag work and doing away with the curly cable between mixer and boom. No more getting hooked up/tangled on stuff.
To be honest I'd like to see NeverClip implemented into the ZMT Phantom but I assume it isn't possible to fit all that magic into such a small box. With such a light and small TX, look forward to seeing my American brothers and sisters enjoy why so many of us prefer to have the TX at the business end of the boom pole.
Honestly when booming I think your foot work, stance and balance are probably more important then your hand work. Understanding how the the whole body/bone structure works will save you so much pain. That's a whole different thread. Never walk flat footed. Use the sides of your foot and roll in as you step. The first point of contact changes depending on the step being made but generally it's the outside edge. Did a job with the SAS (elite soldiers) and we had a silent walk off. Now these guys have been trained. Guess who one. Well they did actually over a rough bush path walking slowly. I kicked their arse at walking at a moderate to quick speed on the same path. They did point out if they had to move that quickly they were probably under fire and quiet footsteps no longer mattered. The point is the were trained to walk the same way I do.
One of the best bits of advice I have read on JW and one that I often neglect.
You are correct Constantin. Pilot tone is actually set to inactive on the IEM just like my brain was set to inactive when I typed my earlier response. I shouldn't respond until I've had my morning coffee intake. Cheers Nate.
Constantin, I'm using a EW300 body pack TX and EW300 IEM. Cheers Nate.
I have a G3 and IEM that I recently brought for boom ops. To me it sounds just as good if not better then my R1a's and has comparable range. Definitely not hissy. I find that the headphone volume on the IEM at around 3 or 4 (Not O'clock) gives a good monitoring level. Mode set to Focus and Balance set to L+R Pilot tone on, on my G3. I have read people needing to have it off. Coming out of my Nomad at line level. I'm new to the system but that's the settings that are working for me.
Hi Trevor. Not sure what Matt has used but you can use cabinet drawer runners and top or under-sling them. They are a bit heavy though, about 250 Grams a set if I remember correctly. Linked an example from Bunnings. https://www.bunnings.com.au/kingslide-400mm-soft-close-drawer-slide_p4020346 I've used a miniature version, that I sourced from a kitchen and wardrobe place, to under-sling a keyboard shelf on to my Rastorder folder cart. Hope the west is treating you well brother. Cheers Nate.
Be careful that Zax stuff is contagious.
Can you elaborate on 'reserved thoughts' on the Ursa thigh straps. I have been thinking about trying them as I find the Neopax thigh straps slip to easily.
In regards to camera links I use a RX200 if audio on camera is to be used in the edit. If it's a guide track (scratch) I use either an ERX or Lectro R1a. Generally I use an ERX, due to size, power efficiency and being able to output GT audio and TC. You do have to take into account that it's on 2.4gHz spectrum and thus has limited range. For most bag jobs range is more then sufficient and I'm not to worried about a couple of drop outs. If I need greater range for whatever reason I'll use a R1a on cam for GT. Based my faulty ears, unscientific testing and on what I use, in order of sound quality I'd say ERX, Sennheiser IEM and then R1a. In range, R1a, Sennheiser IEM and then ERX. If it's simple bag work I tend to use an ERX for director monitor. On commercials and Drama, Zax ERX's go on cameras, Lectro R1a's for Dir/client/Conti and who evers important cousin. Sennheiser IEM for boom. Cheers Nate.
Thanks for keeping us in the loop Gene. I've just emailed you. Cheers Nate.
