I've done some utility work now and have noticed that I need to have a belt with pouches in order to carry a lot of the gear I need through out the day (transpore, scissors, foot foam, wires, connectors, etc.)... I was wondering what everyone was using out there and what they had in the belt kit?
I have an inexpensive tool pouch and belt from Home Depot. The belt is just a simple 2" web belt, the pouch is a general purpose maintenance man's pouch.
In this I keep:
a penlight,
scissors,
a roll of transpore (hangs from the handy tape keeper on the bag),
pen / pencil / sharpie,
small notepad,
sides,
tweeker (2),
a small plastic box with rm-11's and moleskin,
2-4 spare batteries
razor knife,
a roll of black paper tape hangs from a large loop on the belt ready for fast deployment
Also on the belt lives my IFB and, when necessary, the radio between me and production
Anything else that can't be dealt with from this bag is something that needs attention back at the cart, so all those supplies live there.
If foot foaming is an issue, I have a plastic box the size of a shoebox that has all foot foams, furniture pads, and crutch tips inside. I can grab it and fly in with time to spare (presuming I have done my advance scouting job well) to kill those relevant sounds and avoid having to carry all that gak when not really necessary.
I bought a belt once that had a wide back, much like a weight lifters belt, great back support as it clinched tight and had a Velcro buckle. Worked well and saved my back. As, apparently, I have expanded, it doesn't quite fit the way it used to.
  • 11 months later...
Just got this stuff this week, looking forward to using it in the field:
Grip Belt - http://www.sourceshop.com/product.asp?pid=94
Camera Pouch (Customized) - http://www.sourceshop.com/product.asp?pid=90
Portabrace Clip On Velco Cable Tie (Attached to small carabiner threaded through loops for markers)
Flashlight w/case
Leatherman w/case
iPhone/Comtek Case - http://www.sourceshop.com/product.asp?pid=647
post-3351-0-82164400-1365726002_thumb.jp
post-3351-0-03944600-1365726008_thumb.jp
A side note about belts: I use a scuba diving belt( heavy nylon less than $10) . I find it fast to put on and it's easy to go from inside to outside over a bulky coat. If you use a clip style belt you might have to readjust.
