John Blankenship Posted September 10, 2015 Report Posted September 10, 2015 I am judging by the posted specs: rx200 7.7oz QRX235 and qrx200 6oz I understand. That's why I mentioned that "Numbers on product pages are often misleading." A QRX200, without antennas, weights 10oz. Quote
joinwooHK Posted September 10, 2015 Report Posted September 10, 2015 QRX need to be carring an external battery , which in fact need to take into account. I really miss the receiver can be insert battery and run. Quote
Ze Frias Posted September 10, 2015 Report Posted September 10, 2015 I am judging by the posted specs: rx200 7.7oz QRX235 and qrx200 6oz perhaps the listed weight of the RX200 is with internal batteries? I remember holding up the prototype at NAB (which did not have batteries in it) and thinking that it was lighter than the QRX. Quote
Glen Deakin Posted September 10, 2015 Report Posted September 10, 2015 The manual should be on line soon The menu structure is quite similar to the qrx200 just without dual mode items. The rx200 will support XR but not in stereo mode. great thanks Jack Quote
Jason A Posted September 10, 2015 Report Posted September 10, 2015 The manual should be on line soon The menu structure is quite similar to the qrx200 just without dual mode items. The rx200 will support XR but not in stereo mode. That is a real bummer since its primary use is a stereo hop receiver. Is this something that isn't possible due to hardware design, or might be changed later? Quote
John Blankenship Posted September 10, 2015 Report Posted September 10, 2015 perhaps the listed weight of the RX200 is with internal batteries? I remember holding up the prototype at NAB (which did not have batteries in it) and thinking that it was lighter than the QRX. The product page is in error. According to two of my scales, a QRX200 weighs 10oz. (without antennas). According to Glenn, an RX200 weighs in the low 7oz. territory. The NAB prototype was just a mockup. Quote
Wandering Ear Posted September 11, 2015 Report Posted September 11, 2015 That is a real bummer since its primary use is a stereo hop receiver. Is this something that isn't possible due to hardware design, or might be changed later? i thought xr was only mono regardless of the hardware. Am I wrong? Quote
RadoStefanov Posted September 11, 2015 Report Posted September 11, 2015 i thought xr was only mono regardless of the hardware. Am I wrong? Not wrong. XR is mono only... Quote
John Blankenship Posted September 11, 2015 Report Posted September 11, 2015 i thought xr was only mono regardless of the hardware. Am I wrong? No, youre not wrong. Quote
Jack Norflus Posted September 11, 2015 Author Report Posted September 11, 2015 That is a real bummer since its primary use is a stereo hop receiver. Is this something that isn't possible due to hardware design, or might be change later? The modulation takes place in the transmitter. The receiver just decodes the modulation. The RX200 can decode all modulation types - mono, XR, stereo and EU modulation. Quote
Jason A Posted September 12, 2015 Report Posted September 12, 2015 The modulation takes place in the transmitter. The receiver just decodes the modulation. The RX200 can decode all modulation types - mono, XR, stereo and EU modulation. Ahhh, so the Cam Link (or 742) can't transmit a 2 channel signal using XR, correct? Quote
Ze Frias Posted September 12, 2015 Report Posted September 12, 2015 (edited) Ahhh, so the Cam Link (or 742) can't transmit a 2 channel signal using XR, correct? correct. They would transmit using the "stereo" modulation if transmitting two channels. Edited September 12, 2015 by Jose Frias Quote
Jack Norflus Posted September 13, 2015 Author Report Posted September 13, 2015 Ahhh, so the Cam Link (or 742) can't transmit a 2 channel signal using XR, correct? yes but if the 742 is sending a mono you can transmit it using XR. Quote
Jack Norflus Posted September 26, 2015 Author Report Posted September 26, 2015 Looks like Christmas came early. Quote
Jason A Posted September 28, 2015 Report Posted September 28, 2015 Looks like Christmas came early. Looks good Jack! Really curious about some real world AA battery life tests. Have you had a chance try out any of our common rechargeables yet? Eneloop, imedion, etc? Quote
RadoStefanov Posted September 28, 2015 Report Posted September 28, 2015 Looks like Christmas came early. what I want to know is how hot does it get Quote
Jack Norflus Posted September 28, 2015 Author Report Posted September 28, 2015 what I want to know is how hot does it get virtually no heat. Quote
John Blankenship Posted September 28, 2015 Report Posted September 28, 2015 P = I x E therefore: 140ma @ 12v = 1.68w. -- likely dissipated over most of the metal surface of its enclosure. Quote
Jack Norflus Posted September 28, 2015 Author Report Posted September 28, 2015 Looks good Jack! Really curious about some real world AA battery life tests. Have you had a chance try out any of our common rechargeables yet? Eneloop, imedion, etc? With lithium AA I got just over 11 hours. Quote
Jason A Posted September 30, 2015 Report Posted September 30, 2015 With lithium AA I got just over 11 hours. Good to know. Tried out any rechargeables yet? Quote
boodschap Posted September 30, 2015 Report Posted September 30, 2015 I'm planning on getting a QRX200. Or should I get a QRX235? Does QIFB does anything that can't be done through Zaxnet on my Nomad? Or am I totally wrong... Quote
Jack Norflus Posted September 30, 2015 Author Report Posted September 30, 2015 I'm planning on getting a QRX200. Or should I get a QRX235? Does QIFB does anything that can't be done through Zaxnet on my Nomad? Or am I totally wrong... For bag use you don't need the 235. Your nomad can do everything you need - with a better interface. If you were using it on a camera then the 235 might be a better option. Quote
boodschap Posted October 1, 2015 Report Posted October 1, 2015 For bag use you don't need the 235. Your nomad can do everything you need - with a better interface. If you were using it on a camera then the 235 might be a better option. Thanks! Quote
Glen Deakin Posted October 7, 2015 Report Posted October 7, 2015 Manual for the rx200 is up. Thanks zaxcom. Quote
