480sound Posted May 2 Report Share Posted May 2 I'm looking for suggestions about how to handle multiple, (3) actors in full body robot like costumes. They need to have full duplex coms with each other and the director. The production said do you have comteks for the actors. Yes, but do you understand that the actors own dialogue need to be iso'd (is that a word) from their comtek feed otherwise it will feed back to them and cause a distracting echo that will likely be too much for their own intelligibility. Another problem is the 2 way coms I'm familiar with like the HME systems that the camera departments use; have a large headset and boom mics which probably wouldn't work in a full body enclosed costume. Any other 2 way coms that would require a "Push To Talk" are obviously out of the question because the actors can't physically do it. I have easily done 2 way phone conversations with 2 separate comtek transmitters and a mix minus on the actors iso outputs. I have 3 comtek transmitters and 4 Lectro IFB's which I could conceivably make into 3 separate actor feeds and still have IFB's for everybody else; like the director, the crowd (which I call the Video Village audience) the booming and utility and maybe camera department (which could be operators and assistants), still need to take care of AD's and possible effects crew and PA's. There sure are a lot of crew out there that need to follow along. Any of your suggestions and observations would be appreciated. Say a prayer for us here in New Mexico this year it our turn for our state to burn. Quote Link to comment Share on other sites More sharing options...
Mungo Posted May 2 Report Share Posted May 2 Hands-free? Maybe have a look at sports referee com systems or, even better, horseriding comms like Ceecoach ... They're Bluetooth based, but range is practical. Quote Link to comment Share on other sites More sharing options...
BAB414 Posted May 2 Report Share Posted May 2 Check out this article: https://www.lectrosonics.com/press-releases/836-gotham-sound-gears-up-for-lost-in-space-with-lectrosonics.html Also, I'm pretty sure there is some knowledge out there from Simon Hayes who did Prometheus (a space-suit movie with practical comms). This article is about The Martian: https://www.local695.com/magazine/the-martian/ Quote Link to comment Share on other sites More sharing options...
Matthias Richter Posted May 2 Report Share Posted May 2 did you test (yourself) how bad it would be if one hears oneself in the Comtek feed? If it’s an analog system there shouldn’t be any delay. Quote Link to comment Share on other sites More sharing options...
Moesound Posted May 2 Report Share Posted May 2 We do this all the time on our show. You’ll need two Comtek systems. You mic the actor. However you send the directors feed to the actors (earwig, earbud, one ear), use one transmitter that’s sending only the VOG mic. The other transmitter (on a separate frequency, of course) you feed the actors mic. Director hears actor only, actor hears VOG only. Regards, Moe Quote Link to comment Share on other sites More sharing options...
BAB414 Posted May 2 Report Share Posted May 2 I had an on set emergency where they thought the actors could just be on the phone with each other (as per the script) but there was no cell service. Haha! So I gave the actors the full mix in their ears and they were total pros about it. YMMV. Try to ask or do a test with the actors. They may not mind hearing their own voices at all. Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted May 2 Report Share Posted May 2 The actors usually don't mind hearing themselves if the mix is such that they are way lower in it than the incoming feed. In fact I found that some of them were made nervous if they could NOT hear themselves--it made them think the system wasn't working or that the director couldn't hear them. Quote Link to comment Share on other sites More sharing options...
Wandering Ear Posted May 10 Report Share Posted May 10 Sometimes hearing yourself in the comms can eliminate the "plugged ear" effect, especially when only wearing 1 ear. Quote Link to comment Share on other sites More sharing options...
boomhead Posted May 10 Report Share Posted May 10 On the movie "Interstellar" we had spacesuits and helmets. Each suit was rigged with a lav, an SMV transmitter, an earpiece and a Lectro R1A. All wires received into a 788 and output mix minus for each actor transmitted via Lectro SMV in IFB mode. The actors could hear each other, no issue with hearing themselves or feedback and the individual mics were clean. The director had a wireless push to talk mic fed into 788 and out to the actors while he listened to a Comtek with the mix. This whole system was very portable and scalable up to 7 actors. We also had one "robot." That actor had the same setup but we used a headset mic since he didn't have a helmet. To complicate things the robot was also rigged with a powered speaker so his voice could be audible to the astronauts when they took off their helmets. Quote Link to comment Share on other sites More sharing options...
syncsound Posted May 17 Report Share Posted May 17 On 5/10/2022 at 4:53 PM, boomhead said: On the movie "Interstellar" we had spacesuits and helmets. Each suit was rigged with a lav, an SMV transmitter, an earpiece and a Lectro R1A. All wires received into a 788 and output mix minus for each actor transmitted via Lectro SMV in IFB mode. The actors could hear each other, no issue with hearing themselves or feedback and the individual mics were clean. The director had a wireless push to talk mic fed into 788 and out to the actors while he listened to a Comtek with the mix. This whole system was very portable and scalable up to 7 actors. We also had one "robot." That actor had the same setup but we used a headset mic since he didn't have a helmet. To complicate things the robot was also rigged with a powered speaker so his voice could be audible to the astronauts when they took off their helmets. Great sounding work! Quote Link to comment Share on other sites More sharing options...
