DanieldH Posted August 3, 2022 Report Posted August 3, 2022 I am not even sure where to put this topic, so it ends up in the camera department. I've seen some shots on YT some time ago with some GoPro or alike on a boom during take in the past. I can't find them anymore, but it was, in a way, pretty cool portraying our craft. It seems I have a 20min or so sequence shot coming up in a month or so. Hidden cuts expected. Booming this, I'd love to provide some making of footage. So far, the lightest thing my research found was the DJI Action 2, but it's the mounting accessories and their weight specs. struggle me. Has anyone done such a thing in the past or watched it or has any other thoughts beyond "don't put more weight on the boom on sequence shots". And BTW sequence shot experience is also welcome, though I do have some. Thnx Quote
Olle Sjostrom Posted August 4, 2022 Report Posted August 4, 2022 Great idea, but weight would really concern me too as a boom operator. But if the boom is cabled and the transmitter is on the bottom, A tiny camera like that might not make all that much difference at the end of the pole. But even though it's cool, do you really have to put it on the end of the pole looking at the operator? I mean, putting it on the chest or the head of the operator might be equally fascinating. Quote
DanieldH Posted August 5, 2022 Author Report Posted August 5, 2022 On 8/4/2022 at 7:16 AM, Olle Sjostrom said: do you really have to put it on the end of the pole looking at the operator? The frame will roughly be the POV of the mic but with the mic slightly on the edge of the frame. It can be used in sync, split screen or PiP, with the actual footage or other making of cameras. Quote
Michael Render Posted August 5, 2022 Report Posted August 5, 2022 Are the shots static enough to put your boom on a c stand? Then weight wouldn't be an issue. Or you could use a Boom Swinger from Boom Buddy to get leverage. I always keep a Boom Swinger in my kit for those fatiguing shots. Quote
Olle Sjostrom Posted August 5, 2022 Report Posted August 5, 2022 7 hours ago, DanieldH said: The frame will roughly be the POV of the mic but with the mic slightly on the edge of the frame. It can be used in sync, split screen or PiP, with the actual footage or other making of cameras. Yes, of course, that makes a lot more sense Well why not try it? My experience is that static booming is difficult and heavy, while running and/or moving a lot is a lot easier. In those cases I can go on for a very long time, however heavy the pole. Standing still however... Quote
Philip Perkins Posted August 5, 2022 Report Posted August 5, 2022 Sorry, the camera dept. will not be allowed to colonize my mic booms. They can get their own. I have been asked about this a few times and demurred. Quote
Constantin Posted August 8, 2022 Report Posted August 8, 2022 You could also consider something like this: https://amzn.eu/d/gkhAHL7 which is much lighter, but not as good obviously. Especially picture stabiliser is missing (I think), but it’s also much cheaper…. Quote
DanieldH Posted August 10, 2022 Author Report Posted August 10, 2022 Hey Constantin... Thnx for the input. I've researched some of these spy cams, but I'll stick to this particular action cam. mostly due to availability of accessories and since it is a camera that is made to be moved around. Quote
DanieldH Posted September 7, 2022 Author Report Posted September 7, 2022 Current rehersal setup Quote
SeanMAC Posted September 7, 2022 Report Posted September 7, 2022 Definitely have thought about doing this myself, closest I've ever gotten is putting a phone in my boom bag with my MM-1 and facing the lens out. Would love to see the results whenever you get them! (Also probably a bit too late, but a Ktek Squid might have worked as a mounting option. Hard to do fine adjustments though to get that mic in the shot) Quote
IronFilm Posted September 8, 2022 Report Posted September 8, 2022 On 8/4/2022 at 5:16 PM, Olle Sjostrom said: But even though it's cool, do you really have to put it on the end of the pole looking at the operator? I mean, putting it on the chest or the head of the operator might be equally fascinating. Or even mounting it say half way along the pole could still give a very interesting perspective, while not being nearly as much weight as putting the camera on the most extreme end of the pole itself. Quote
