chris_bollard Posted June 16, 2012 Report Share Posted June 16, 2012 A first today; rolling 3 tracks recording to int. hdd and CF and everything locked up. The display and audio, only passing low level high frequency whistle. Had to pull the battery off to reset. All settings were good as was timecode. Anyone had this? Running 2.15 and CL8 Quote Link to comment Share on other sites More sharing options...
atheisticmystic Posted June 16, 2012 Report Share Posted June 16, 2012 Hey Chris, My 744 locked up like that just two weeks ago with the high frequency whistle. LSC said "it's a computer, it happens". Best Quote Link to comment Share on other sites More sharing options...
RPSharman Posted June 16, 2012 Report Share Posted June 16, 2012 I began a thread about this a while back. Some users have experienced the phenomenon. For me, it's happened once in countless hours of use on my 788T. Never happened on my 744T with many more hours of use. It is a computer, and is remarkably reliable considering that fact. Quote Link to comment Share on other sites More sharing options...
Sean McCormick Posted June 16, 2012 Report Share Posted June 16, 2012 Haven't had that one yet (praise Jeebus)... The only issues I've ever had since October 2009 were CF and FW400 ext media dropouts when running 8 simultaneous tracks for really long reality takes (or too soon after booting up). Quote Link to comment Share on other sites More sharing options...
chris_bollard Posted June 16, 2012 Author Report Share Posted June 16, 2012 Happened once in 18 months continuous use. Not that bad considering..... Quote Link to comment Share on other sites More sharing options...
TimPitot Posted June 16, 2012 Report Share Posted June 16, 2012 I've had it once. 7 tracks. Its happened to lots of people - see the SD forum. Quote Link to comment Share on other sites More sharing options...
Jon Gilbert Posted June 16, 2012 Report Share Posted June 16, 2012 Happened to me once on my 744T. Quote Link to comment Share on other sites More sharing options...
pvanstry Posted June 16, 2012 Report Share Posted June 16, 2012 Happened to me a couple of times. Basically it freezes and locks itself on the last sample it recorded feeding it back non stop. Simply recycle power and your good to go. Aside from that no issues, daily use for the last 3 years. All good. It's te best investment I made so far. Pascal Quote Link to comment Share on other sites More sharing options...
Matt Bacon AMPS Posted June 16, 2012 Report Share Posted June 16, 2012 A first today; rolling 3 tracks recording to int. hdd and CF and everything locked up. The display and audio, only passing low level high frequency whistle. Had to pull the battery off to reset. All settings were good as was timecode. Anyone had this? Running 2.15 and CL8 It was the CF card's fault when it happened to me. Quote Link to comment Share on other sites More sharing options...
Derek H Posted June 16, 2012 Report Share Posted June 16, 2012 Happened to me a couple of times. Basically it freezes and locks itself on the last sample it recorded feeding it back non stop. Simply recycle power and your good to go. Aside from that no issues, daily use for the last 3 years. All good. It's te best investment I made so far. Pascal So do you lose the recorded audio in this scenario? Quote Link to comment Share on other sites More sharing options...
Plainlabel Posted June 17, 2012 Report Share Posted June 17, 2012 Only happened to me once. Recording to 3 media. However, cart was outside in 95 degree weather. Seemed to be a heat issue. Now I run a fan in the case when ambient is high. No issues so far since. Used 744t two summers outdoors in las Vegas heat. Never locked up, zero issues with orig 40gb hard drives. Quote Link to comment Share on other sites More sharing options...
Peter Mega Posted June 17, 2012 Report Share Posted June 17, 2012 So do you lose the recorded audio in this scenario? All audio is intact up to the point of freeze so no worries, just the inconvenience. Chris, it happened to me twice this year and I'm pretty sure both times was due to bad CF card supplied by production. Quote Link to comment Share on other sites More sharing options...
chris_bollard Posted June 17, 2012 Author Report Share Posted June 17, 2012 The CF is mine. Probably record cycled 20 to 30 times without any issues. Not overly worried about it; when you think about how many times other pieces of gear fault. More curious if anyone else has had the same problem. Quote Link to comment Share on other sites More sharing options...
TimPitot Posted June 17, 2012 Report Share Posted June 17, 2012 I don't think mine was card-related. Just a 788T brain fart I think. Quote Link to comment Share on other sites More sharing options...
pindrop Posted June 17, 2012 Report Share Posted June 17, 2012 I've filled up a 160GB hard disk about 4x over, recording on multiple Transcend CF's in parallel (but never to 3 media or external media) and never had a freeze - touch wood. But had one random media too slow which I was wondering was associated with the rather lengthy (up to 2-3 minutes I think) disk access that sometimes goes on after boot up not finishing fully, or with heat, it was about 35C? Quote Link to comment Share on other sites More sharing options...
VM Posted June 17, 2012 Report Share Posted June 17, 2012 It never happened to my SD788. Good to know that you didn't loose audio... Quote Link to comment Share on other sites More sharing options...
hemmerlinj Posted June 18, 2012 Report Share Posted June 18, 2012 It's happened to me Atleast 3/4 of the time I've ever used one. I don't own one so they've always been a rental. My guess was the cards being used. Quote Link to comment Share on other sites More sharing options...
VASI Posted June 18, 2012 Report Share Posted June 18, 2012 Update firmware: Quote Link to comment Share on other sites More sharing options...
