Nathaniel Robinson Posted April 16, 2014 Report Share Posted April 16, 2014 That is exactly what I want in a bag cart. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Jan McL Posted April 16, 2014 Report Share Posted April 16, 2014 As always, Pascal...thoughtfully, thoroughly and aesthetically well accomplished. Quote Link to comment Share on other sites More sharing options...
John Ronnerblad Posted April 16, 2014 Report Share Posted April 16, 2014 Wonderful. I want exact that. Does that handle comes with the case? Skickas från min iPhone via Tapatalk Quote Link to comment Share on other sites More sharing options...
pvanstry Posted April 16, 2014 Author Report Share Posted April 16, 2014 Thanks Jan, coming from you ( tweaking cart master ) I really appreciate it. John, the handle is the standard one on the 2750 stormcase. Quote Link to comment Share on other sites More sharing options...
John Ronnerblad Posted April 16, 2014 Report Share Posted April 16, 2014 Thanks Pascal. You are an inspiration. I'll just have to figure out how to find drawers here in Sweden that will fit that case:) Skickas från min iPhone via Tapatalk Quote Link to comment Share on other sites More sharing options...
gavin Posted April 18, 2014 Report Share Posted April 18, 2014 Very nice job! Quote Link to comment Share on other sites More sharing options...
John Ronnerblad Posted April 18, 2014 Report Share Posted April 18, 2014 I need to find out more about this Pascal... Is that frame the one that Peli case sells? And what's the measurements of those drawers? Skickas från min iPhone via Tapatalk Quote Link to comment Share on other sites More sharing options...
chriskellett Posted April 18, 2014 Report Share Posted April 18, 2014 Very well done, thank you for sharing. Quote Link to comment Share on other sites More sharing options...
pvanstry Posted April 18, 2014 Author Report Share Posted April 18, 2014 I contacted a company called Multicaisse, here in Montreal to built the case. I basically ask for aluminium drawers in a stormcase IM2750. They got the case, then built a custom aluminium frame, built the drawers, installed it all and shipped it to me. I then replaced the original rollerblade rear wheels with a solid aluminium axle and two 6" offset Rack n roller wheels. Then installed two 2.5" locking swivel caster on the front so that it could stay up and leveled. Then added two PVC tube with end cap on the side, held in place by Velcro. This is as far as this project will go for now, as I am now building a custom 8020 cart/case. It will be based around Greg Sextro mini cart design. Quote Link to comment Share on other sites More sharing options...
John Ronnerblad Posted April 19, 2014 Report Share Posted April 19, 2014 Thanks! Skickas från min iPhone via Tapatalk Quote Link to comment Share on other sites More sharing options...
azw Posted April 19, 2014 Report Share Posted April 19, 2014 Anyone know someone in NYC who fabricates drawers like these? Quote Link to comment Share on other sites More sharing options...
fieldmixer Posted April 23, 2014 Report Share Posted April 23, 2014 Seriously thinking on having one of these made. I would like to attach a 20" c-stand riser section on the side where pascal has the boom pole holder tubes. I imagine It would involve reinforcing the plastic case side with a pair of aluminum plates for mounting a bracket. I've gone through catalogs of grip gear and mounting hardware but can't seem to find what the ideal bracket would be for this application. Can anyone that has been there and done that, or something similar, point me in the right direction? What brackets are used to attach antenna masts? Quote Link to comment Share on other sites More sharing options...
Ken Wilkinson Posted April 23, 2014 Report Share Posted April 23, 2014 No drawers here but figured you guys might appreciate my Magliner water cooler bottle bag cart. Four folding shelves built in. Quote Link to comment Share on other sites More sharing options...
Michael Panfeld Posted April 23, 2014 Report Share Posted April 23, 2014 Filedmixer: the C-stand risers are junior pins (i.e., the turtle base is a Junior receiver 1 1/8"). You can certainly buy a Matthews or other brand Junior pigeon plate, or any other junior mount. Quote Link to comment Share on other sites More sharing options...
fieldmixer Posted April 23, 2014 Report Share Posted April 23, 2014 Thanks Michael. I'm unfamiliar with the nomenclature of those bits. Cheers! Quote Link to comment Share on other sites More sharing options...
Michael Panfeld Posted April 23, 2014 Report Share Posted April 23, 2014 Try anything on these pages that says Junior: http://www.msegrip.com/product/hardware/plates.html http://www.msegrip.com/product/hardware/hangers-holders-brackets.html Quote Link to comment Share on other sites More sharing options...
fieldmixer Posted April 24, 2014 Report Share Posted April 24, 2014 Indeed. The only piece that *might* work is the set wall bracket. Does it work inverted? don't know. With modification it could sit flush on the side of the case I suppose. So far unable to find any variation on this. Say, a simple vertical receiver with backing plate. must be out there somewhere. Found this bracket that might work also. Difficult to tell with out having it in hand. Quote Link to comment Share on other sites More sharing options...
Jeremy Childers Posted May 14, 2014 Report Share Posted May 14, 2014 This is awesome Pascal! this is exactly what i need in a case/cart! Now i need to find a place in so cal to do the drawers...ant ideas guys? Quote Link to comment Share on other sites More sharing options...
RPSharman Posted May 14, 2014 Report Share Posted May 14, 2014 Metal drawers at Rackman in Sylmar - Steel or Aluminum. Terry Jr. will hook you up with stock or custom drawers. Wood drawers on sliders in some sort of custom case... I use A & S Cases. But there are others. Quote Link to comment Share on other sites More sharing options...
Jeremy Childers Posted May 14, 2014 Report Share Posted May 14, 2014 @RPSharman thank you! Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
John Ronnerblad Posted May 19, 2014 Report Share Posted May 19, 2014 Since I can't get this "Peli case drawer cart" out of my head I have been looking for options. I found this Canadian company: http://www.ops-inc.ca/index.cfm/products/pelican-products/pelican-case-storage-drawer-system/ Skickas från min iPhone via Tapatalk Quote Link to comment Share on other sites More sharing options...
fatfatjames Posted July 23, 2014 Report Share Posted July 23, 2014 I don't use my Pelican tool case that much anymore. It's definitely a kick ass soution for packing stuff up, taking to cargo, put on a palette, but the case is prohibitively heavy to travel on domestic air flights. It's been to Ecuador and back, but that's about it. Tom where did you get your sponge cut? Quote Link to comment Share on other sites More sharing options...
JackHenry Posted September 9, 2014 Report Share Posted September 9, 2014 Pascal where did you source the aluminium drawer corners and frames seen in the very first image of this thread? Quote Link to comment Share on other sites More sharing options...
pvanstry Posted September 9, 2014 Author Report Share Posted September 9, 2014 Jack, I had all my case built by a place here in Québec called Multicaisse. Standard case builder. Real good stuff. I do the design and also add stuff after it's built. Quote Link to comment Share on other sites More sharing options...
JackHenry Posted September 9, 2014 Report Share Posted September 9, 2014 Thanx Pascal. I'm in Australia. I've tried Googling several terms for those parts without success. Do you know what the correct name for them is? Quote Link to comment Share on other sites More sharing options...
