The screen, I believe, is the exact size - or very close to the QRX screen.
But the new OLED screen has way more pixels and much better resolution than the QRX screen. It is a brilliant display that really needs to be seen in person.
  • Replies 294
  • Created
  • Last Reply
Top Posters In This Topic
We will be looking for customer feedback on the OLED display before we do anything else with it. I am very happy so far with the look of the display and it seems like it will be the way forward.
We will be delivering the RX200 soon and we will see.
Glenn
There are a number of pieces of kit I know of that operate on external dc with the on/off switch turned to the off position. The obvious one that always amuses me are my Audio Ltd EN2 transmitters. when on INT batteries the on/off switch works as normal, and when on ext dc they will be on so long as there is dc present, including when the on/off switch is in the off position!!!
The zaxcom trx900AA behaved the same way.
With an STA adapter attached, the external power is on in the off position and is off in the on position.  Put another way, the transmitter's power switch manually selects between internal battery power and external power furnished via the STA adapter.
i dont need dual mode in a camera link - although i have seen dual mode in camera link setups used in very clever ways. when i do see a need for it the 235 will always be here for that purpose. for some clients (really just 1 at this point) i still need record run tc where the 235 would serve that purpose. the return is another thing i dont need. i have never been satisfied with the fidelity from headphone ports. i would prefer a sennheiser g2 just for return mounted to the top of an rx200 if i felt i really needed return. I just placed an order as well for my rx200. see you in september! hopefully...
-Ken
Dual mode would have been great for smaller lighter bag setup.
Is the filter qrx235 or qrx200 like?
With batteries installed, and DC connected, will the unit use DC until it is not present and then switch to the internals? Or will it drain the internals regardless?
it will use the higher voltage source first. So external then switch over.
So I'm assuming range is the same as qrx235 and qrx200....
yes. Perhaps even slightly better.
wait so rx200 doesn't have dual mode? :/ It would be nice to throw in a bag if needed while not using on camera.
There seems to be some misunderstanding as to the design and purpose of this unit.
It's 1/2 of a QRX200 with an internal battery compartment and time code reception via the UHF signal, built into a small, lightweight form factor.
That means it receives from one transmitter, either mono or stereo depending upon the transmitter.
the rx200 is a single receiver. It can receive a signal channel from a mono transmitter or two channels from a stereo transmitter. The single receiver allows the rx200 to be smaller then a qrx and extremely power efficent.
While the rx200 was primarily designed to be used as a camera mounted receiver it can also work in a bag - though it is a single receiver.
 Copy that makes sense, just wanted to confirm. Thanks!
Posted (edited)
Jack or Glenn do you know when there will be a manual for the RX200 online to read?  Also might have already mentioned before but  i have did not see In Mono mode does the receiver support XR Modulation?
Edited by Glen Deakin
The manual should be on line soon
The menu structure is quite similar to the qrx200 just without dual mode items.
The rx200 will support XR but not in stereo mode.
So the audio transmission is same quality as QRX ? It would be nice if rx 200 in the bag , one mic need and in extremely mobile situation with no external battery is need for the receiver .
Loo
Looking at specs RX200 is a lot heavier then QRX200.
