I am having phantom power poping problems with my nomad. Is this a software issue or a hardware issue? The poping is very intermittent and extremely bothersome. Any suggestions?
  • Replies 1.8k
  • Created
  • Last Reply
Top Posters In This Topic
Is a very common failure (on early Nomads), I had a unit with a strong pops on several inputs (with and without phantom), now I have a new one with some noise in two inputs ( still waiting for a new input board)
  • 3 weeks later...
" i 'm shure i had the correct cable for this purpose..the SB-T and the cable are from a very serious rental compagny..."
so?  they could be supplying a cable that works with other gear...
" I first thought the cable was faulty, so i tried 3 or 4 other cables. "
where were these from ?  theycould have been the same incorrect wiring...
did you try the test suggested...
" i Just don't like not understanding why.. "
It could be the cable, or it could be the box...
I agree with you Michael, vf isn't an enjoyable mixing experience for me either.
Hoping for an external fader module in the future. And panning... Uhg.
Before I posted my question I had checked the site first for any suggestions. I stumbled across a a post in which Glenn said there are no plans for an external fader module. =(
What about 2 Emergency Rx's? That's what I'd try.
I've never seen those. Looks pretty slick.
Thanks for the suggestion.
No problem. That's the easiest way I could think of that gives you a physical fader. I haven't actually test it out yet though. I could today to see if it works if you'd like.
Yes, but having to toggle between each fader isn't really working out for me. I need something quicker then that.
I had seen your post before on this. How is this working out for you?
Hmm wasn't me. It is in the to do list as I want a mix pre anyway as a backup mixer. Also, funny story- I was in a dub stage with mark yesterday when you sent someone over to pick up something for anodizing ;) small world.
Fader control can be easily accessed directly from the ENG home screen. Nomad can be setup to directly access channels 7 and 8 only.
Pressing the menu encoder will toggle between the 2 channels. The virtual fader screen is not necessary at this point.
Glenn
Glenn
Thanks. I'll give it a try.
Hi Everyone,
I was wondering if there is an experienced (15+ years ) Location Mixer who is familiar with a Zaxcom Nomad config who can do a 1-day training session for common location sound practices. I'm new to the production sound industry and would like someone in the LA,OC,SD (California) area to show me the ropes using a Nomad. If you are interested please email me with your name, years of experience, available equipment, rate(for half day or full day) and contact info: yoshi@tallgrasspictures.com
Thanks,
Yoshi
Hi Everyone, I was wondering if there is an experienced (15+ years ) Location Mixer who is familiar with a Zaxcom Nomad config who can do a 1-day training session for common location sound practices. I'm new to the production sound industry and would like someone in the LA,OC,SD (California) area to show me the ropes using a Nomad. If you are interested please email me with your name, years of experience, available equipment, rate(for half day or full day) and contact info: yoshi@tallgrasspictures.com Thanks, Yoshi
Why do you think someone who has 15 years experience knows more about a machine that's less than 2 years old? Regards Chris W
