boomsound
1 Follower
    SE US
    Experienced Sound Mixer and Boom Operator. Twenty five years and counting.
2,453 profile views
  1. I use a Lectro UCR100 for standard link. Camera has to use a box as I only have mini to xlr cables. Direct for line and the gray padded (-45db) for mic.
  2. I saved the cardboard sleeves my IDX NP-1's came in and i've never had an issue (domestically and internationally). The agent told me to just make sure I take them out of my carry-on to be scanned.
  3. I'd like to give a personal testimony. I sent three Sanken Lav's to Kristian. He quickly repaired and shipped them with the metal connector. Solid connector, solid repair, solid service. I highly recommend having your Lav's repaired by him. Jeff
  4. I remember as well and I would be interested in buying some also. Anyone?
  5. Alex, I can help you out. I have several pelican cases that are wired already. Just need to add a new battery.
  6. No one in the US offers this service for boom poles? Okay, any suggestions for somewhere I can send it?
  7. I have a Vdb boom pole that needs a cleaning/tune up. Any recommendations to send here in the US? Thanks!
  8. Booming for Al McGuire in Utah (1997).
  9. I used the door trim as well. It uses a heat sensitive adhesive that for me, got messy down here in Florida. I've had to peel it off and clean the residue several times. I tried silicone and so far it's been fine.
  10. I used the mini output to the headphone in jack on the iPad. Scripty asked if I could do it and I wanted to find out. I thought you could use the stereo cable for a DSLR, so I tried it and adjusted the output level of the Tig.
  11. The script super asked me to jam her iPad Pro with TC. She's using Movie Slate. I used a standard mini stereo to stereo, but couldn't get it to jam. Has anyone done this with success? Thanks.
  12. Thanks for the responses. I'm not so concerned about the physical installation (but I will heed your advice), it was more about getting the OS onto the new drive. OWC suggests doing a clean OS install before adding saved data from the old drive. Marc, which SSD drive did you buy?
  13. I have a Mini 2011 that I want to update to an SSD. My first concern is, how easy is it to install an operating system to the new drive? This was recommended before migrating content from the old drive. Second, which have you used or would recommend, Crucial or OWC SSD? Thanks in advance!
