jozzafunk
Everything posted by jozzafunk
  1. Thanks Peter Yes, it all needs to be removable on the daily To clarify on my post - I’m trying to optimise what we’ve got - cheers
  2. I’m helping out some friends that have a worship space - They recently converted the big rear room into a yoga studio / devotional music space which gets loud - There used to be a big shrine type arrangement blocking the rear windows but that has moved and the neighbours are complaining. we need to build some plugs to go into the 2 large window cavities. They can be 200mm deep ( not ideal ) but this also will make them more manageable. The plan is 3 plugs - 1200mm wide by 1200 high that fit in each window space . I’m looking for advice on the composition Currently looking at ( with materials to hand ) From inside room to window. 18mm ply to 70mm Audex foam Then airgap then foam then another layer ply, to make them 200mm deep, and boxing around outside to hold together. Do folk think this is best layering for sound proofing? Was considering long thin slots in front ply to help act as traps / diffusers. Any opinions on whether slots would compromise proofing over benefits it may provide? thanks for your time and help will also be building baffles and getting some carpet but the plugs are needed asap there is a pretty limited budget but some handy folk there JAS
  3. Bide your time. Most holographic pres’ I’ve ever heard
  4. Uncle Google and auntie jwsound aren’t coughing up the answer Ive a Deva IV with updated board - anyone know if this means it has timecode on the hirose 10 pin ( as does fusion ). Cheers and thanks in advance JAS
  5. I recently wired 3-4 people during training for periods on a boxing doco, they wore singlets for all the training. I used mm400s in a padded belt, pack on side with b6S with k tape - Depending on the fabric/sweat levels. they stayed on ok or were hopeless and fell off. Need a few tape options/colours. Some visual signs were acceptable to the director but once on they weren’t too bad at all ( unless the Lav fell off ) If I do it again I’ll either get mic bras or stitch the mics in / stitch a little pouch and probably use a different Lav maybe b3 The wires definitely got a bunch or stuff I’d never have got on the boom, with 2 shooters on zooms. The boxing gyms were full of bright lights and mirrors presenting booms their own set of issues as well.
  6. Have had a bit of a look but can’t find clear answer - Can anyone advise whether these older units with the UDM power and rf distro supply power for active antennae - appreciation in advance
  7. Thanks for This. Had to knock one up quickly for shoot last couple of days when the camera didn’t show up with an adaptor c@ble
  8. So in summery, based on reading the replies - ‘neverclip’ doesn’t actually do that - It’s a tool that when used correctly ( which exactly how seems to be difficult to explain ) can help prevent clipping. Thus recordists with this facility, expect it to prevent clipping, run hot levels, and what you’re hearin’ is good old fashioned distortion from limiters. I presume this also because I went thru the same thing, and instead use gain staging ( and Sonosax limiters ) regards
  9. jozzafunk
    Crickets
    I was measuring cicadas nearing 90dB with a sound metering app earlier this year - some long days - whole feature at 1 location, historic house - the constant din was draining all the crew - The script was rewritten to try deal with the noise - it’s not finished yet so not sure of outcome post has best cicada atmos ever Soundfield thru a Sonosax sxst8
  10. Truly superb advice
  11. jozzafunk
    Crickets
    What Phil said + tighter wilds if poss
  12. I just finished a gig where a certain HOD was called 48fps - moved twice as fast and did half as much
  13. Ahhhh wish I’d read this last week
  14. Have you turned up the TC output level on the ERX - I jam my mozegear boxes from ERX but it needs to be at the highest level for them to register input. ive recently had issues jamming Alexa minis with ERXs and after some research including reading how someone did some testing recently and found the Zax tc output to be a bit lo fi and thus falling below Alexa tc spec - Perhaps similar situation with the mixpre requiring cleaner tc
  15. Yep there’s some dodgy energiser lithiums around for sure. I’ve recently had a few brand new packs that are all or some NG almost straight away - cant trust em anymore
  16. Nek minit - somebody's plugged DC into the audio
  17. jozzafunk
    Zoom F8n.
    I have neither so can't really comment sorry - tho have been using a 633 almost daily since they arrived in New Zealand, and find it to be superb - reliable / user friendly mostly / great upgrades / light / well specced If you want my 2 cents about those 2 - hard to say - 664 would cover most, if not all jobs I deal with - the additional options the 688 dsp provides don't seem worth the price difference but if you doing reality / panels regularly dugen would be invaluable I would say and I'd guess would pay for itself in a few days
  18. Interesting test - fairly apparent differences even just on the laptop, but very difficult to be objective - the Sonosax sounds so 3D!!
  19. Seems to be fairly large difference between the 2 just on the lappy speakers - not much bottom end on the me2, probably more lav than tx/rx, me2 1/4 of price of mke2
  20. jozzafunk
    Zoom F8n.
    Not at all, it's not rocket science, some stuff is better than other stuff, if you've got the option you use the better stuff - there's no point arguing subjectivity, that's what kicked off this conversation in the first place.
  21. jozzafunk
    Zoom F8n.
    What is your point? As I read it you were inferred a renowned recording artist recorded vox on lo-fi cheap gear, however you were completely mistaken, so er, what was the point being made? Anybody can use anything to do some sort of job, a pro / craftsperson will use the best gear they can. 633 preamps are better than f8 preamps / the difference is a very apparent difference that counts to a few people initially and many more down the line whether they know it or not / If you don't think initial quality counts you either have low production values, poor hearing, poor monitoring or haven't done much post mixing / they are also more expensive / you get what you pay for / technology is changing, you get more for less, not necessarily a good thing / there's a good reason vinyl is having a resurgence .... IMHO ( except for pre quality matter, that's just a fact ) I'll probably get a f8n as backup / extra tracks, but I would much rather 788 / 688 / nomad
  22. it'sin the outputs routing menu, green is post fade / blue is pre or something like that Says it on the page
  23. When I first started in the industry about 12-13 years ago I worked for about the first 2 years in a busy production office without really having a lunch break - I broke down after a while and became really angry and sad and had to take 6 weeks off to stare out the window. It was an amazing experience that I value to this day - I learnt a lot about myself and where my 'edges' were. It's good to know ones limits, there's possibly better ways of discovering them
