Ryan Posted February 12, 2013 Report Posted February 12, 2013 After doing a show in Canada in the freezing cold and snow, I wanted to find out what the best and easiest way to waterproof an XLR connection is, between two cables. I had 4 PA towers, and that's a lot of XLR breakouts of snakes, as well as 200 foot runs with 2 100' XLR cables that are connected where there was snow and melted snow. Also, it was about -10C when I was setting up, so using e-tape and plastic bags was a time-wasting activity, not to mention annoying because I was wearing snowboard gloves and I had to take them off to peel the e-tape with my fingernail every time I had a new one to do... So, is there a simple way to waterproof 2 XLR connectors? I've been searching and searching, and there isn't really a commercially available product specifically made for XLR connectors, so I've been searching deeper into things I can repurpose for this job - such as bicycle handlebar grips... garden hose couplers... etc. etc. etc. What have you guys done that waterproofs your connections quickly and something you can hopefully do with heavy warm gloves on? Some of the shows I'll be doing in Russia, Canada, Europe... all outdoors and VERY cold... I've looked at Saran wrap, but I'm a little weary of it because of the pollution aspect of it... Thanks in advance!!! Quote
AndyB Posted February 12, 2013 Report Posted February 12, 2013 Saran wrap covered with gaff tape might work pretty well, but not with the heavy gloves. I can't really think of anything that would work and be easy to use with heavy gloves. I'll keep wracking my feeble brains... Quote
jason porter Posted February 12, 2013 Report Posted February 12, 2013 I believe Neutrik makes a water protected XLR connector set. Or, if it is physically possible, get the junction point off the ground so it can't sit in water or snow. Quote
Freeheel Posted February 12, 2013 Report Posted February 12, 2013 My first suggestion would be 200 ft xlrs, but that fixes your problem by creating huge coils of cable. Second suggestion would be a small Tupperware container, notched at each end where the cable goes through. Cheers Brent Calkin Quote
Hartley Posted February 12, 2013 Report Posted February 12, 2013 Markertek sells Tomy tape: http://m.markertek.com/product/list/self-fusing-silicone-tape/http:%7C%7Cwww.markertek.com%7Cmobile%7CExpendables%7CGaffers-Tape-Adhesive%7CSelf-Fusing-Silicone-Tape.xhtml I have used this alot and it works well. It may not be the cheapest solution but it does work. Quote
ShubiSnax Posted February 12, 2013 Report Posted February 12, 2013 I use a ziplock bag. Cut the bottom two corners off, feed each end through the holes, and connect them inside the bag. Use electrical tape to seal the corners of the bag with the cables running through. Hope this makes sense, been up for 36 straight hours.. Quote
Toy Robot Posted February 12, 2013 Report Posted February 12, 2013 Have you tried Nexcare waterproof medical tape? It's what I use on boom and cables to waterproof connections and I have had great success so far. It's available at most drugstores, not too expensive, highly waterproof, stretchy to cover oddly shaped connections and adheres to itself very well. As a side note, I don't know how that tape will fare in the cold conditions you are discussing. Quote
Ray Collins Posted February 12, 2013 Report Posted February 12, 2013 You pull on this stuff, stretch it, and wrap both XLR's from cable to cable. http://uteck.com/magic_wrap.html Turns to solid rubber so to get the XLR's apart you will need a box cutter, it seals very well, and doesn't bleed like electrical tape. I've found it at Lowes and Hime Depot in Canada, and I believe it is a Canadian product. Only issue I have had is they sometimes cut the roll incorrectly and it won't stretch properly as the grain is the wrong way around. If it snaps when you stretch it they have screwed up. Quote
Derek H Posted February 12, 2013 Report Posted February 12, 2013 Markertek sells Tomy tape: http://m.markertek.com/product/list/self-fusing-silicone-tape/http:%7C%7Cwww.markertek.com%7Cmobile%7CExpendables%7CGaffers-Tape-Adhesive%7CSelf-Fusing-Silicone-Tape.xhtml I have used this alot and it works well. It may not be the cheapest solution but it does work. You pull on this stuff, stretch it, and wrap both XLR's from cable to cable. http://uteck.com/magic_wrap.html Turns to solid rubber so to get the XLR's apart you will need a box cutter, it seals very well, and doesn't bleed like electrical tape. I've found it at Lowes and Hime Depot in Canada, and I believe it is a Canadian product. Only issue I have had is they sometimes cut the roll incorrectly and it won't stretch properly as the grain is the wrong way around. If it snaps when you stretch it they have screwed up. I think these two are great suggestions. The "tommy tape" is also the same as "rescue tape". All of these work by sticking to itself without the use of an adhesive. Many adhesives fail in the extreme cold so that rules out gaffers tape and probably electrical tape but these suggested tapes will work as they stretch tightly around things and then sticks to itself and forms a permanent bond when pressure is applied. They leave zero residue also which is great. As mentioned you do have to cut it off but that's easy. I also like the tupperware idea! Don't get frostbite! Quote
Mirror Posted February 12, 2013 Report Posted February 12, 2013 I inherited some XLR cables with Tommy tape on the ends. I remember that stuff was hard to get off. I believe I used a utility knife and a lot of swearing. Quote
Tom Visser Posted February 12, 2013 Report Posted February 12, 2013 I've used underground electrical splicing tape, probably similar to the tape mentioned above, where it is self molding / adhesive and cuts apart as a single cocoon with a razor (be careful). Quote
GrahamTimmer Posted February 12, 2013 Report Posted February 12, 2013 http://www.littlegreenhouse.com/accessory/electrical.shtml Quote
Ayip12 Posted February 12, 2013 Report Posted February 12, 2013 this is the best.... http://www.plastidip.com/home_solutions/Plasti_Dip Quote
jonathan chiles Posted February 12, 2013 Report Posted February 12, 2013 +1 for Nexcare tape, did take the black coating off my K-tek CCR section though! Quote
engaudio Posted February 12, 2013 Report Posted February 12, 2013 I use these from neutrik. http://www.neutrik.com/en/xlr/x-hd-series/nc3fx-hd-b They've worked for me, so far.. Grant. Quote
Jeremy Childers Posted February 12, 2013 Report Posted February 12, 2013 PVC pipe withe caps on both end, pre drill holes on set u seal the hole with any of the options above, gets the connection off the ground and can be done wearing heavy gloves Quote
graham Posted February 12, 2013 Report Posted February 12, 2013 I've haven't used it but thought this would be good. http://m.homedepot.com/p/Nashua-Tape-Stretch-and-Seal-1-in-x-10-ft-Silicone-Sealing-Tape/100206050/ Quote
GrahamTimmer Posted February 12, 2013 Report Posted February 12, 2013 I have not used these particular connector covers, I could not find the ones I bought 12 years ago, that are still working fine btw. I have two carts so storing them is not a problem. If the OP is wearing a backpack while carrying over 1000 feet of xlr plus multiple breakout boxes and P.A.'s then, well he has other troubles. I understand if your working out of a bag these may not be for you but I don't and they work very well for keeping moisture out of connectors. Having waterproof connectors on every cable is an expensive and maybe not practical solution. Although I do see the merits, personally I have never used them. I work in Vancouver BC one of the rainiest cities in the PNW. I have lots of experience in the rain and this is my recommendation. Best, Graham Quote
GrahamTimmer Posted February 12, 2013 Report Posted February 12, 2013 Oh btw I do like your plastic sleeve option as well. Best, Graham Quote
nwstudios Posted February 12, 2013 Report Posted February 12, 2013 When doing most types of tape solutions the professional way is to use electrical tape for the first couple layers with the sticky side out. This makes it much easier to remove. Quote
GrahamTimmer Posted February 12, 2013 Report Posted February 12, 2013 I think when the goal is waterproofing a connection sticky side out might be impractical. Best, Graham Quote
nwstudios Posted February 12, 2013 Report Posted February 12, 2013 I think when the goal is waterproofing a connection sticky side out might be impractical. Best, Graham Only the first layer or two. Then tape normally. Example 2 layers of Scotch 88 sticky side up 2 layers of Scotch 130 linerless rubber, this stuff pretty much melts together. 2 layers of Scotch 88 sticky side down for a finish layer. Quote
berniebeaudry Posted February 12, 2013 Report Posted February 12, 2013 I like the ideal of the self fusing tape and the 3M sleeves. No adhesive to worry about then. I would fold over and secure the sleeve above the connector with a small cable tie. Then start the tape around the sleeve and work your way up the cable away from the connector. The idea is like applying shingles on a roof. You start at the lowest point and work your way up so the water runs over the tape layers not into them. This really helps if the cables are hanging. Also, if they're hanging the male shell should be on top so if moisture does get in, the water will run over and not into the connector. If the cables have to lay on the ground then seal both ends the way I described. Do try to keep them elevated if you can. To make it easier to remove the tape, leave a tear off tab to help get it started. If you use electrical tape it can work in cold temps if you keep it in a pocket near your body. You'd use the same technique and maybe wouldn't need the cable tie. If you stretch and break the e tape you can make a tear tab there too so you don't have such a hard time starting it again. I've seen whole sideline assemblies and hardware in plastic tubs with holes cut in the sides, off the ground, for cables to go into and out of. The whole multi ends/breakouts can live in there and be out of the weather for the most part. You would just need some foam or something stuffed in the holes to keep blowing snow out. Put a cable tester on all your long cables before you go out so you won't have to tear things apart and trouble shoot out in the field. Sorry this got so long, but hope its useful. BB Quote
john Quinn Posted February 12, 2013 Report Posted February 12, 2013 http://www.primrose.co.uk/dribox-weatherproof-outdoor-electrical-connection-pi-36396.html How about something like this Best John Quote
berniebeaudry Posted February 12, 2013 Report Posted February 12, 2013 http://www.primrose.co.uk/dribox-weatherproof-outdoor-electrical-connection-pi-36396.html How about something like this Best John Those look pretty good! Where do you buy them? Quote
