Michael Miramontes Posted December 4, 2013 Report Posted December 4, 2013 Need to think about it a little further though, because unless your producers that are also monitoring with an ERX from the same audio feed like to hear beeps all the time too, you'll want a second IFB path. I use Lectro R1 units for client monitor because they are superior in range then an ERX without an amplified IFB signal. There I said it. Quote
Zack Posted December 4, 2013 Report Posted December 4, 2013 Well, I think you're going to get some resistance for your idea due to the fact the ERX can be used in different situations than an R1 can. Quote
Michael Miramontes Posted December 4, 2013 Report Posted December 4, 2013 Well, I think you're going to get some resistance for your idea due to the fact the ERX can be used in different situations than an R1 can. True, an ERX can be used for different situations, which is why they are just one of the tools in my kit. Quote
fieldmixer Posted December 5, 2013 Report Posted December 5, 2013 I like the idea of a double beep in headphone when you hit stop though. Quote
John Blankenship Posted December 5, 2013 Report Posted December 5, 2013 I like the idea of a double beep in headphone when you hit stop though. That's what I use. It's good to have aural confirmation when you start recording and when you stop. Quote
Wandering Ear Posted December 5, 2013 Report Posted December 5, 2013 That's what I use. It's good to have aural confirmation when you start recording and when you stop. Record/stop beeps are wonderful. I also like that the beeps are higher pitched when recording 96k as opposed to 48. Quote
Zack Posted December 5, 2013 Report Posted December 5, 2013 Record/stop beeps are wonderful. I also like that the beeps are higher pitched when recording 96k as opposed to 48. The pitch of the beeps do follow the sample rate with Zaxcom recorders. This has always bothered me for some reason lol. Quote
Wandering Ear Posted December 5, 2013 Report Posted December 5, 2013 The pitch of the beeps do follow the sample rate with Zaxcom recorders. This has always bothered me for some reason, Funny, i really enjoy it. A subtle confirmation for me since i don't change sample rates often, i don't want to see it on screen all the time. Quote
Michael Miramontes Posted December 5, 2013 Report Posted December 5, 2013 Howie or Glenn, Can the beeps be easily implemented? Quote
Christian Spaeth Posted December 6, 2013 Report Posted December 6, 2013 I suggested this a long time ago, for another scenario where my boom op wears an ERX and would, by hearing the beep, know that I'm rolling, so I wouldn't have to shout "rolling", or tell them through com every time I start recording. I still think this would be a good addition. Quote
studiomprd Posted December 8, 2013 Report Posted December 8, 2013 " Ok Senator, this is when you say..."DSLR's are for shit productions" " I've never said that (about any dSLR) and such beeps need to be an option! Quote
RkRall Posted December 9, 2013 Report Posted December 9, 2013 Can someone explain in layman's terms how the input compressor and the track compressor work and relate to each other? I see you have the option of enabling the compressor but then you have settings for track compressor and input compressor (not to worried about output compressor yet). Is there anyway just to have one of them enabled? For what I use the nomad for I just need the track compressor and i'm also trying to understand how they relate to each other. Thanks in advance Quote
Derek H Posted December 9, 2013 Report Posted December 9, 2013 I think the beeps you're looking for could be done most easily by creating a "momentary" mode for the tone button. Then you would just manually send your beeps... I don't like the idea of the machine sending beeps to the outputs or record tracks unless I hit a specific tone button, ever. Quote
johnpaul215 Posted December 9, 2013 Report Posted December 9, 2013 I think the beeps you're looking for could be done most easily by creating a "momentary" mode for the tone button. Then you would just manually send your beeps... I don't like the idea of the machine sending beeps to the outputs or record tracks unless I hit a specific tone button, ever. I can see uses in narrative work. When doing doc work that I won't cut for hours, I still tap record when there is a big change. Say we are driving to a location while talking to a subject, then seamlessly get out of the car and go do something. I will push record to start a new track as we get out of the car. Even if it just makes my sound reports easier for post to follow, it makes sense to me. In that case I would not want beeps on camera. I can see that uses for his boom op knowing that you heard cut or that you are rolling. Thing with my wireless boom setup is that I use a MM1. My boom ops don't get a feed from my cart unless I push talkback. I don't know if it's unusual or not, but I rarely work with a boom up that wants to hear a feed for my cart that has lavs etc. Quote
John Blankenship Posted December 9, 2013 Report Posted December 9, 2013 I wouldn't want to have to send beeps manually every time we roll or stop. If the beeps that are currently available in the main headphones had a routing menu, that would offer complete flexibility. However, a simpler fix would be a single additional menu item that would also route them to HP2 when they're engaged. It's certainly not high on my list, but it could be nice to be able to send them to the boom op, too. Quote
studiomprd Posted December 9, 2013 Report Posted December 9, 2013 RkRall: " settings for track compressor and input compressor (not to worried about output compressor yet). " the tracks are what you record. they are outputs of the mixer (including ISO's) you are going to need to read up on signal flow: Jay Rose's books at www.dplay.com Quote
DodoHu Posted January 3, 2014 Report Posted January 3, 2014 Still working on jobs with punch in recordings. Right now, I need to rent other equipment than zaxcom to use as audio daw interface for a computer. That brought me to the idea, why the nomad couldn't do the job? It has great preamps, it has a usb interface. Wouldn't it be great, if it could be hooked up to protools, logic cubase or other software as the audio interface? Then zaxcom wouldn't have to worry about programming overdubbing. Quote
studiomprd Posted January 4, 2014 Report Posted January 4, 2014 DodoHu? " zaxcom wouldn't have to worry about programming overdubbing. " that is if they were worrying about programming overdubbing... Quote
rich Posted January 5, 2014 Report Posted January 5, 2014 and, just because it has a USB connector (the wrong one than what would be typically used for this) doesn't mean that it is capable or ever will be capable of being used directly as an audio interface. i disappointed you missed that one Senator. Quote
dominiquegreffard Posted February 25, 2014 Report Posted February 25, 2014 Hi all, for nomad/maxx owners there is a facebook group called zaxcom nomad / maxx owners. I just discovered it this week and it seems pretty active and yet another good source of information. Jack is there wich is always a good thing. I just wanted to throw it outthere for those (like me) who didn t know. Cheers! Quote
Jack Norflus Posted February 25, 2014 Author Report Posted February 25, 2014 https://www.facebook.com/groups/682199065139938/ It is open to anyone - you don't have to be a Zaxcom user. You do however have to register to post anything to prevent spam. Quote
James Arnold Posted February 26, 2014 Report Posted February 26, 2014 It's a great little resource! Quote
bendybones Posted April 3, 2014 Report Posted April 3, 2014 First time using Fader Assign. Am I missing something obvious or can I not assign a fader to return3/4? Quote
Jack Norflus Posted April 3, 2014 Author Report Posted April 3, 2014 First time using Fader Assign. Am I missing something obvious or can I not assign a fader to return3/4? No you can't assign return 3/4 to a hardware fader. There is some reason, though I forget exactly why it cant be done. Though you should be able to assign then to a fader with the new expansion panel. Quote
bendybones Posted April 3, 2014 Report Posted April 3, 2014 what's this about an expansion panel? did I miss some news? should i be tho excited? back to the fader assign: I would love to know why rtn3/4 have been left out, just for curiosity. And that being so, it would make sense that in vFader cycle if we could select just 9 and 10. I have 7 and 8 (rtn1/2) on a hardware fader but still need to cycle thru those two inputs in vFader to get to 9/10. Strange, no? Quote
