Matt Sisco Posted February 13, 2023 Report Posted February 13, 2023 20 hours ago, Matt Sisco said: I have installed firmware version 9.2 on my 888 with SL-2. There are 8 selectable slot inputs seen by the 888. However only the first two channels of each slot are passing audio when I run tone from all four channels of the DSR4. Additionaly, it does not automatically switch the DSR4 outputs from analog to AES. I’ve submitted the bug to Sound Devices. Anyone else experiencing this? Update on the SD v9.2 firmware issue I mentioned above. Apparently the SL-2 cannot use a digital receiver in one slot and an analog receiver in the second. When I use just the DSR4 by itself all 4 channels output as AES3. When an SRC is in the remaining slot the SL-2 forces the DSR4 back to analog outputs and you only get 2. Was in communication with SD support on this today. The firmware update was only intended for 2 DSR4s. Quote
EnotsMedia Posted February 14, 2023 Report Posted February 14, 2023 Ooof…hate to be THAT guy…but this issue or function was already discussed earlier in this thread. Way before these units were even shipped. The SL2 settings are global, all AES or all ANALOG. Whenever powering up the 8 series (w/ SL2) if the SRC is off and DSR4 is on it WILL default to AES. But if SRC is on (w/ DSR4 in SL2) it will default to ANALOG. RTFM? Quote
codyman Posted February 14, 2023 Report Posted February 14, 2023 If you really want a DSR4 + an older analog SR, you could use a PSC Four Pack + Sound Devices 8 Series AES "barnacle". You'll lose 8 series integration but you'll save $600+, gain a power distro (built into the four pack), and save yourself another $4500+ from buying a 2nd DSR4 if you don't really need it. It's a bit work 'roundish but it is an option. Quote
Blackdawg Posted February 15, 2023 Report Posted February 15, 2023 Those of you that are using one of the DSR4's with the EXT back plate(analog), what were the connectors on the included power cable? Quote
codyman Posted February 15, 2023 Report Posted February 15, 2023 14 minutes ago, Blackdawg said: Those of you that are using one of the DSR4's with the EXT back plate(analog), what were the connectors on the included power cable? As always, pigtails (I believe that's the proper nomenclature?) Quote
mlemaudit Posted February 21, 2023 Report Posted February 21, 2023 Just to make sure is the SL-2 will fully work digitally with one DSR4 and one DCR822? Quote
r.paterson Posted February 21, 2023 Report Posted February 21, 2023 1 hour ago, mlemaudit said: Just to make sure is the SL-2 will fully work digitally with one DSR4 and one DCR822? Dcr822 isn't a slot receiver it's a stand alone receiver like a 411a. Quote
Matt P8 Posted March 24, 2023 Report Posted March 24, 2023 Any updates on the DSR Dual-Channel version? Quote
Matt P8 Posted April 3, 2023 Report Posted April 3, 2023 This just in from Gotham Sound: “Lectrosonics let us know that the release of the 2 channel DSR has been delayed for upgrades to the RF performance as well as to more closely match the front panel of the recently released DSR4. These improvements will most likely cause a 2 or 3 month delay.” Quote
Dejan Ceko Posted November 5, 2023 Report Posted November 5, 2023 Aaton Hydra supported with the latest firmware. FW 3.530.C12 - November 02, 2023 Cantar X3 3.530.C12 (02-11-2023) New features: - Hydra compatibility with the new Lectro DSR4 HF receiver (Four Channel Digital Slot Receiver). After seated the DSR4 in his slot, a reset of the Tx location is needed once. Quote
karlw Posted November 10, 2023 Report Posted November 10, 2023 On 11/5/2023 at 1:57 AM, Dejan Ceko said: Aaton Hydra supported with the latest firmware. FW 3.530.C12 - November 02, 2023 Cantar X3 3.530.C12 (02-11-2023) New features: - Hydra compatibility with the new Lectro DSR4 HF receiver (Four Channel Digital Slot Receiver). After seated the DSR4 in his slot, a reset of the Tx location is needed once. This is great news, Dejan - thanks for posting! Quote
Matt P8 Posted February 22, 2024 Report Posted February 22, 2024 Necropost just to report that the DSR was TOTALLY worth the wait! Quote
JonMoore Posted February 24, 2024 Report Posted February 24, 2024 On 2/22/2024 at 9:10 AM, Matt P8 said: Necropost just to report that the DSR was TOTALLY worth the wait! 100%. The DSR4 is awesome. The main delta for me is the lack of USB-C on the front panel. But that's about it. Quote
