Everything posted by Jim Rillie
To my ears, having used both, they are the speaker equivalent of 7506s (which I used for many years, but had to go away to something that more reflected what was really there) .
The Hydra board for the PSC sixpack works for all the receivers in that sixpack - 2 six-packs with Hydra equals 12 channels of Hydra info. you can adjust all major parameters from the Cantar interface, and the display is excellent. No more fiddling around with hard to read receiver displays and fussy little buttons. Definitely a big plus for ham fisted old codgers like me. OK, that's all. I should not get into the other reasons some of us use the Cantar. Demo one, if you can, and give it a few days. Then you will be a little better prepared to make that decision. Same goes for the Scorpio - try before you buy.
Science question: Schoeps CMIT startup fart noise - what is happening?
Jim Rillie replied to Izen Ears's topic in Equipment
Only one of my CMITs exhibits this. The others are normal bump at startup. It is the second one I bought. -
Curious about the distance between antenna and antenna
Jim Rillie replied to gwak ki nam's topic in Equipment
Use to do that tape and rubber band trick with my old Microns. They had fairly long cable antennas Channel 13 VHF. -
Comtek issue, rhythmic tapping or clicking sound
Jim Rillie replied to MikeCorl's topic in Equipment
iPower 9volts have worked well for us for years when bagging it. The ticking may be caused by other things, like an LED dimmer, or cell phones too close in my experience, anything that radiates RF, but your experience leads to battery. -
Tentacle Sync MK1 Battery Replacement with Pictures
Jim Rillie replied to Elusive Sounds's topic in Do It Yourself
Thanks, Vin. That is good to know. -
I'm with Mr Gooch on this, not because I have any experience in Africa, but when working internationally as I have a few times, I would always recommend bringing your own equipment (assuming you have a kit). A Carnet makes international travelling with gear workable. Oftentimes your producer can get a Carnet for sound, and camera in the same document.
Thank, you Patrick. That is what I thought. I do currently adjust my receive 620s for that very reason, also using back pattern null for interfering signals. just like using a cardioid pattern on a mic to advantage.
Hello group, Is anyone using this antenna for comms? I am using a dipole at the moment for our crew comms signal from a DCHT to M2R receivers. Range is generally less than the incoming range of a DPR. Would like to get more usable signal range out to the crew with their M2Rs. Since the ALP 620 has a lot more gain than a dipole, will using the shark fin give us noticeably more range? Since the 620 is passive, I think the 50 mW signal will not harm the antenna. Or am i wrong? Best regards, Jim Rillie
Wow, never heard of that one in my experience.
We have found with an SNA 600 on the antenna mast connected to the transmitter with an extension cable, the range is much better.
Haven’t had any kinks. They have worked well from Day1. Our only issues have been with battery loading in the M2Rs. Very difficult to close the cover with rechargeable AAs. We always get them closed but with resistance. Hoping with age they will loosen up to a happy medium. And the sound is great. IMHO.
A shark fin is a log periodic antenna AFAIK.
I guess a lot of us have gas ; - )
Looks like CAT6 has 4 twisted pairs with claimed very low crosstalk. Maybe you could add XLR gender benders at each end on the returns, or roll your own XLR to ´Ethernet fanouts. Just a thought. No guarantees.
I have one, have been using it for about 4 or 5 years now. Mine is not regulated AFAIK (no options). The ability to turn stuff on and off individually from the K Art switches is great for regulating the cart current draw, and the power meter is great, just like the smaller boxes. I also have a BGDh with battery cup hard-wired for the doc setup. Never had any voltage issues, maybe because none of my outlets seem to be regulated. After all, most of the professional quality equipment we use already has its own regulation built in so to speak.
Maybe EV cardioid RE15s/? More reach than a 635, which was often used much closer than those overheads.
One thing - if you are monitoring on headphones, the room reverb will be more noticeable than when monitoring a speaker - maybe it's not as bad as you think. Just a randy Canadian opinion ( - ;
Looks like it works for bacteria, doesn't seem to mention viruses.
My experience with SSM battery life matches Constantin’s
The description says the unit works with 75kHz deviation , or is that a typo? I thought all transmitters with UHF analogue transmission were now 50 kHz deviation by law.
