alidav Posted July 31, 2018 Report Share Posted July 31, 2018 what is the performance of both the windshields for a mkh40 outdoor use, (low wind condition). I have used always indoor or in an ms configuration in a Rycote basket with a windjammer, now I want to use it alone for a series of 2 persons interview sitting on a terrace. Quote Link to comment Share on other sites More sharing options...
Tom Visser Posted July 31, 2018 Report Share Posted July 31, 2018 Babyball, baseball is pretty much an indoor thing and will mostly lead to frustration when used outside if the wind comes up. Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted July 31, 2018 Report Share Posted July 31, 2018 5 hours ago, Tom Visser said: Babyball, baseball is pretty much an indoor thing and will mostly lead to frustration when used outside if the wind comes up. Agreed. Quote Link to comment Share on other sites More sharing options...
alidav Posted July 31, 2018 Author Report Share Posted July 31, 2018 the babyball and baseball, have a different price and are totally different, the baseball has a windjammer too, so it is intended to be used outdoor, my question what is the baseball performance outdoor, it gives some help more than the basic foam sold with the mic? so there is not differences in buying baseball or baby ball, the first costs 30 $ the second 100$, if working indoor even the basic antipop foam is ok. Quote Link to comment Share on other sites More sharing options...
VASI Posted July 31, 2018 Report Share Posted July 31, 2018 The bigger the windshield the better. Quote Link to comment Share on other sites More sharing options...
chrismedr Posted July 31, 2018 Report Share Posted July 31, 2018 1 hour ago, alidav said: my question what is the baseball performance outdoor, it gives some help more than the basic foam sold with the mic? yes, the baseball with fur is better then the basic foam, the baby ball with fur is even better yet. but what people try to tell you that it's still risky, because you might start with a baby ball and everything seems great, but in the middle of the interview stronger wind comes up and you have to stop the interview and switch to a fully enclosed wind shield (you usually don't make many friends in that situation). so, most people prefer to use a full wind shield outdoors to start with and not worry anymore. chris Quote Link to comment Share on other sites More sharing options...
Mobilemike Posted July 31, 2018 Report Share Posted July 31, 2018 Just now, chrismedr said: so, most people prefer to use a wind shield outdoors anyway and not worry anymore. chris +1 Cinela Leo-25 works great for the MKH40. -Mike Quote Link to comment Share on other sites More sharing options...
Robert Bluemke Posted August 1, 2018 Report Share Posted August 1, 2018 I’ve used the baseball with the furry overcover on my MKH50 in light breeze and it’s been ok. Anything stronger than a breeze and I will use my baby ball. Quote Link to comment Share on other sites More sharing options...
Ilari Sivil Posted August 4, 2018 Report Share Posted August 4, 2018 I've had success with a Baby Ball Gag with Oktava MK012s which are really sensitive to the wind. The BBG is very effective with the fur on, it also helps if you make sure that the capsule itself is positioned in the middle of the ball gag. Taping off the switches should also help, as advised on this video: Quote Link to comment Share on other sites More sharing options...
alidav Posted August 11, 2018 Author Report Share Posted August 11, 2018 On 8/4/2018 at 12:35 PM, Ilari Sivil said: On 8/4/2018 at 12:35 PM, Ilari Sivil said: I've had success with a Baby Ball Gag with Oktava MK012s which are really sensitive to the wind. The BBG is very effective with the fur on, it also helps if you make sure that the capsule itself is positioned in the middle of the ball gag. Taping off the switches should also help, as advised on this video: taping of the holes does not affect the polar diagram? On 8/4/2018 at 12:35 PM, Ilari Sivil said: On 8/4/2018 at 12:35 PM, Ilari Sivil said: Quote Link to comment Share on other sites More sharing options...
Glen Deakin Posted August 11, 2018 Report Share Posted August 11, 2018 Taping the switches does not affect anything. It has nothing to do with the pick up pattern. Quote Link to comment Share on other sites More sharing options...
Mobilemike Posted August 11, 2018 Report Share Posted August 11, 2018 40 minutes ago, Glen Deakin said: Taping the switches does not affect anything. It has nothing to do with the pick up pattern. I think it’s more that if the wind is really blowing hard, it could possibly find its way into the mic body and to the capsule through the switch. Quote Link to comment Share on other sites More sharing options...
Glen Deakin Posted August 11, 2018 Report Share Posted August 11, 2018 That's what I meant. Taping the switch won't affect the polar pattern. Just prevention of possible wind getting in through the switch openings. Quote Link to comment Share on other sites More sharing options...
alidav Posted August 11, 2018 Author Report Share Posted August 11, 2018 57 minutes ago, Glen Deakin said: Taping the switches does not affect anything. It has nothing to do with the pick up pattern. sorry ive seen the video on smartphone, it seem at the beginning that he tape the holes next the capsule, before taping the switches Quote Link to comment Share on other sites More sharing options...
osborne456 Posted August 12, 2018 Report Share Posted August 12, 2018 Cinela Leo-25 with fur works in moderate wind for an MKH 50. Quote Link to comment Share on other sites More sharing options...
pindrop Posted August 12, 2018 Report Share Posted August 12, 2018 19 hours ago, Glen Deakin said: Taping the switches does not affect anything. It has nothing to do with the pick up pattern. Eh! If wind can get to the capsule through the switch apertures quite clearly, then so too will sound even more clearly, now whether that is fairly negligible is one thing, but it will have an effect. And as we all know with these top end mics the difference is subtle and each one has a signature, I wouldn't mind betting that switch aperture has a definite effect on the subtle signature of the MKH 50..... Quote Link to comment Share on other sites More sharing options...
daniel Posted August 14, 2018 Report Share Posted August 14, 2018 On 8/12/2018 at 2:41 PM, pindrop said: Eh! If wind can get to the capsule through the switch apertures quite clearly, then so too will sound even more clearly, now whether that is fairly negligible is one thing, but it will have an effect. And as we all know with these top end mics the difference is subtle and each one has a signature, I wouldn't mind betting that switch aperture has a definite effect on the subtle signature of the MKH 50..... Effect similar to choice of wind protection, how well brushed the fur is, shape of suspension etc? Or maybe more, as they're part of the mic body? I use a short piece of bicycle inner tube to cover the switches on my MKH 50. It rolls back for the switches and it can hold a small piece of a toothpick for flicking them. Probably playing havoc with the sound signature but the tube stays in place more conveniently than tape and the toothpick can be handy for fixing the teeth after lunch and before wiring up Quote Link to comment Share on other sites More sharing options...
