henrirapp Posted February 21, 2020 Report Posted February 21, 2020 Quote Rigging a lavalier with the capsule popping out from just behind a button is one of my favorite lav micing techniques. Because the capsule is actually exposed, it has virtually no clothing noise and a much more natural and open sound. This strength also leads to this technique's biggest downside; since the capsule is exposed and has no wind protection so it can easily suffer from wind noise. This makes it really only useful if talent will be indoors the whole time. This is my preferred technique anytime talent is wearing a button down shirt indoors Read Full Article at: https://henrirapp.com/lavalier-technique-buttonhole-rig/ Quote
anzel2002 Posted February 29, 2020 Report Posted February 29, 2020 that is a good idea, looking, sounding good Quote
NickFriedrich Posted February 29, 2020 Report Posted February 29, 2020 I just ordered a couple of 6060s to bring this technique into my arsenal. The film I'm working has so many buttoned down shirts, sometimes with open jackets ontop. Its lav-nightmare, no matter what. Quote
Matthias Richter Posted February 29, 2020 Report Posted February 29, 2020 get some B6 too. I found the 6060 is still too big to hide behind a button. It’s fine for a wide shot. But nowadays with 2 cameras and different sizes you get f...ed pretty quick. Quote
BAB414 Posted March 1, 2020 Report Posted March 1, 2020 If I did what the guy in that picture did, the costumers would look at me like I'm crazy. I get away with B6's behind big buttons, but the mic in that picture is bigger than the button it's hiding behind. Quote
NickFriedrich Posted March 1, 2020 Report Posted March 1, 2020 look at the article. I think the previewed picture here shows the process of hiding, not the final placement. Quote
BAB414 Posted March 1, 2020 Report Posted March 1, 2020 6 hours ago, NickFriedrich said: look at the article. I think the previewed picture here shows the process of hiding, not the final placement. You are correct. But even the final picture would never fly on any show I've worked on. If you can see it at all, it's a no-go. Quote
OnTheSoundSideOfLife Posted March 1, 2020 Report Posted March 1, 2020 I used this technique outdoors aswell without any additional wind protection. No issues. Granted there was no wind, but I was still surprised that fast walking didn't create any kind of problems. Quote
Constantin Posted March 1, 2020 Report Posted March 1, 2020 For me it’s hit and miss. Sometimes it works sometimes it doesn’t. Like so many times with lav mics. Sometimes it does work outdoors, but the again I sometimes get „nose breather“ and then even indoors sitting down won’t work, because these people manage to breath right into the microphone Quote
TVPostSound Posted March 3, 2020 Report Posted March 3, 2020 On 3/1/2020 at 2:54 PM, Constantin said: For me it’s hit and miss. Sometimes it works sometimes it doesn’t. Like so many times with lav mics. Sometimes it does work outdoors, but the again I sometimes get „nose breather“ and then even indoors sitting down won’t work, because these people manage to breath right into the microphone It’s Omni, turn it upside down!!! Quote
Constantin Posted March 3, 2020 Report Posted March 3, 2020 1 hour ago, TVPostSound said: It’s Omni, turn it upside down!!! yes. And no. It’s an omni but it still sounds different upside down. Still that is a good way, but not always. Cable management becomes trickier Quote
Jason Nightall Posted March 28, 2020 Report Posted March 28, 2020 I've done something similar to this in the past and had issues with the shirt rubbing the cable from behind so I like the idea of using the double sided rycote sticky to keep the two sides of the shirt in place. Thanks Quote
henrirapp Posted March 31, 2020 Author Report Posted March 31, 2020 On 2/29/2020 at 10:02 PM, BAB414 said: If I did what the guy in that picture did, the costumers would look at me like I'm crazy. I get away with B6's behind big buttons, but the mic in that picture is bigger than the button it's hiding behind. On 3/1/2020 at 10:44 AM, BAB414 said: You are correct. But even the final picture would never fly on any show I've worked on. If you can see it at all, it's a no-go. Yeah, might not be the best technique for narrative productions, unless you are using something like a black lav on a black shirt, etc. I'd say its really more of a technique I employ on documentary productions. Sometime its the best option, sometimes it isn't. Just have to use common sense and your best judgment to when it is appropriate. Quote
TomBoisseau Posted March 31, 2020 Report Posted March 31, 2020 We used this very technique about 10 years ago for a couple seasons of "Swift Justice With Nancy Grace", however we used a Countryman B6, which fits quite nicely under a button, and we pointed the element down to minimize air blasts. We secured the mic under the button using "Joe's Sticky Stuff". Given her outfit (at the time it was similar to the blue Delta flight attendant outfits with the "vests" that they used to wear) and the fact that they continued to heavy starch her shirt, it was the only thing we could come up with that worked. Tom Quote
Izen Ears Posted June 5, 2020 Report Posted June 5, 2020 B6 + butyl. That massive, gargantuan lav would be seen by the grips! Quote
Trey LaCroix CAS Posted June 5, 2020 Report Posted June 5, 2020 I do this with a 6060 all the time. Just wish the head down a little, wrap Joes for topstick around the head and you're good to go. Haven't been caught so far! Quote
Ontariosound Posted June 5, 2020 Report Posted June 5, 2020 The host of the Paramount show "Bar Rescue" has his lav mounted in a shirt button most scenes. Jon Taffer is a hot headed chap from what is seen on the show and I bet he got annoyed with adjustments or re-takes due to clothing noise on him so it was decided to have it semi-exposed. It is a very successful show and his mic is almost always visible to the trained eye. And it sounds great. Quote
tourtelot Posted June 5, 2020 Report Posted June 5, 2020 NO ONE but motion picture professionals EVER see lav mics placed by competent sound pros. But I won't say I never got in a fight about it with DPs (almost never camera operators), wardrobe or even the actors themselves. Lav mic'ing is a unique art/science because no matter how long you've been doing it, or your skill level, something that worked "a treat" yesterday may not work at all today. D. Quote
John Blankenship Posted June 5, 2020 Report Posted June 5, 2020 On 3/31/2020 at 2:29 AM, henrirapp said: Yeah, might not be the best technique for narrative productions, unless you are using something like a black lav on a black shirt, etc. ... Black lavs matter. ...too soon? Quote
BAB414 Posted June 5, 2020 Report Posted June 5, 2020 1 hour ago, Ontariosound said: The host of the Paramount show "Bar Rescue" has his lav mounted in a shirt button most scenes. Jon Taffer is a hot headed chap from what is seen on the show and I bet he got annoyed with adjustments or re-takes due to clothing noise on him so it was decided to have it semi-exposed. It is a very successful show and his mic is almost always visible to the trained eye. And it sounds great. They don't VFX it out? 18 minutes ago, John Blankenship said: Black lavs matter. ...too soon? And on pizza: Black olives matter Quote
Ontariosound Posted June 6, 2020 Report Posted June 6, 2020 Bar Rescue is a reality style show. No VFX besides blurring out non-sponsor booze bottles and beer taps. Everyone laved at all times, terrible lighting usually but a great way to kill an hour if you are bored these days. Screaming, crying, fighting, drunk people, bacteria etc etc. I have seen COS 11's and B6's in the button on the host's shirt every episode. Quote
tourtelot Posted June 6, 2020 Report Posted June 6, 2020 But you are looking. My mom isn't. There was a very famous Hollywood mixer (actually in NYC) that you'd know his work, Oscar winner, loads of high-profile pictures who more often than not would put his lavs on in full view. How he won the argument I'll never know. But I have looked at his pictures and yep, there they are. Sure, he worked with wardrobe, and props and so on; maybe a scrap of material, some paint, and what have you. But even I, until I knew, didn't see them, even on the "big-screen". I wasn't looking, the movie interesting enough, actors good enough, shot selection appropriate, didn't need lavs on the close-ups because a $1500 Schoeps sounded better to everyone than a $300 Tram, single camera. You know? A quality and crafted way to work. Oops, sounding like an old guy again. D. Quote
Jim Feeley Posted June 6, 2020 Report Posted June 6, 2020 18 hours ago, BAB414 said: Black olives matter I now feel empowered to mention that I actually first read the subject line of this topic too quickly. I missed the "on" in "Buttonhole." Yes, for real. 😯 20 minutes ago, tourtelot said: But you are looking. My mom isn't. In my little doc/corp world, the hidden-lav thing is perhaps different. And remember the Pennebaker-Hegedus film Startup.com? Go to 1:24 in the trailer below...and that's not the film's most egregious exposed lav. I remember first seeing that and going, "WTF?" Everyone in the theater told me to shut up and sit down. Normal people didn't notice, or didn't care. The filmmakers got the scenes. OK, I'll stop saying something even more obvious that that lav below. Quote
tourtelot Posted June 6, 2020 Report Posted June 6, 2020 I will admit, that placement coulda been done a little better. D. Quote
TVPostSound Posted June 12, 2020 Report Posted June 12, 2020 My most enjoyable season of Top Chef, is when the new sound sup had white lavs in white chefs coat sticking out of button holes. It was so nice not to have to force EQ from behind a canvas coat!!! Even the company's owner didn't notice!! I did!! So, I assume next season the Chefs will be placing they're own lavs...................I QUIT!! Quote
