On 29 December 2015 at 7:05 PM, Olle Sjostrom said:
Exactly. It seems biased, that's the word I was looking for.
To me, the 633 is the closest competitor to the F8 in terms of size, channels and features (given that the F8 has more physical inputs). The 633 is not the much more expensive, and has that Workhorse feeling.
Sorry Olle, but in Australia a 633 costs $5,040, an F8 $1495. That's exactly the kind of bias you're suggesting in the Sound on Sound article!
3.35 times the price is hardly "not much".
The SOS article mentioned also weather proofing as being potentially less on the Zoom, but in fact the F8 has better protection for media slots than, for example, the exposed CF slot for 7 series recorders...for example...
Whilst I don't doubt the 633 more of a workhorse, I do think it's fair to say that the F8 offers incredibly good value for what it offers, and it's build quality is a significant step up from Zoom's earlier consumer recorders...as it's preamp performance.
The 2.0 firmware revision does address some odd shortcomings such as a lack of channel ganging and improved metadata, very soon after it's release...addressing earlier assumptions by some that firmware would be ignored at the expense of new products.
I'm not endeavouring to be inflammatory, nor do I think it will replace professional location sound recordists daily use machines, I simply think it can't be dismissed out of hand as "just a Zoom" [which is something I've done myself in the past].
On 12/27/2015 at 6:20 AM, efksound said:
Playing a bit with the new 2.00 firmware there are loads of improvements, that make this little machine very powerful now !
I've notice also that the machine is configured in Rec Priority mode, so that you can go in record mode from almost any screen on the menu, except from the FINDER, So for example if you are correcting Metadata info for previous takes and need to go into record, you need to exit first and go to the home screen which means a lot of pressings on the menu button (to exit) it would be nice if this could be changed somehow
Also entering Note Metadata but only for the NEXT take is a bit awkwards, how will you know that the next take will be good or bad ?
It would be good also to have the ability maybe to edit Metadata while recording
Would be also nice to have a Edit Note shortcut for example : STOP +TR4 ( which is not used ?)
Thanks for listening Zoom !
Hello,
Thanks for the thoughts. These are all great comments. I will pass them on for consideration as we look to improve the F8 further!
You can edit note Metadata on past take in the Finder menu.
Thank you
1 hour ago, ZoomOfficial said:
Hello,
Thank you
Just my own insight to this, rolling, plane flies overhead, would be nice to enter a note on the currently running clip.  "Cut" is called, PL to boom op (through external mixer since there's no communications feature on board the F8) "no good for sound, plane" and immediately the director tells the AD to go again and we're already speeding up for the next take - no time to go into menus and revisit past clips.  This is one of the reasons I still use paper reports, there's no menus, firmware, or reliability issues with pen v2.0 (upgraded to roller ball from fountain nib) and paper v3.0 (papyrus to immulsified pulp to carbons) or when there is, don't bother contacting the manufacturer or sending in for service, just replace with new one.  Being able to immediately enter notes would be one hurdle to overcome for me to adopt electronic reports.  The other would being able to print directly from the unit.  I don't bring a computer on set and need to hand over reports immediately to production (as we pull equipment through mud and jungle vying for dwindling space on the stake bed trucks in order to get back to base camp).
My question though, could for example, pot #1 be assigned to input gain for the boom mic on channel 1, and then pot #2 be assigned to channel 1 fader?
I got a little lost in the translation. Otherwise, according to José and Samual from Zoom, the line inputs (via 1/4" TRS) are +4dB. ( the manual's specs state max input level as "+34 dBu (at 0 dBFS, limiter ON)"
The main and sub mix outputs are  -10dB line or mic level.
Correct, line level inputs (1/4" TRS) are +4dBu. Outputs are switchable between consumer line level, or "Normal" level as the F8 calls it (-10dBV), and mic level (-40dBV).
VM, Merci pour votre avis. Je dois encore essayer le nouveau firmware.
I received my replacement unit and it also fails the SD performance test with the Delkin cards the dealer provided. Apparently the first unit was perfectly fine and the dealer failed to test the cards like they said they did. At least I know now that the F8 isn't defective.
Hey Tom,
I hear your concerns with the notes and reports. I will pass along.
The pot use that you describe would be interesting. Haven't heard that from anyone yet.
Thank you
5 minutes ago, ZoomOfficial said:
Hey Tom,
Thank you
No, thank YOU for participating.  This communication and interest from the manufacturer makes me feel it is the first time I can take Zoom seriously as a company for "our" professional needs and the F8 still seems quite interesting for me because of a few of the positive design features.
9 hours ago, VAS said:
Audio samples, not working.
It is html 5. Some web browsers seems not to read  html 5 sounds :Internet Explorer up to version 8.0, Firefox and Opera.
So.. I have just put a reader. It should be OK now. Let me know (maybe by PM not to disturb this post)
Vinc.
On 29/12/2015 at 9:47 AM, greyfoxx said:
I look at as somewhere in between the 744t and the 633. Its a 4 channel if you want the safety tracks(compensate for the limiters). I would chose a 633 over it however I personally think its better than a 744t. Now what we need is someone to develop taller knobs that would attach to the F8 knobs. Seems like there could be a market there.
On 29/12/2015 at 10:42 AM, Tom Visser said:
These may already exist.  Anyone know what the shaft type is?  D-flat?  6mm?
Someone on Facebook has just posted this pic using 788T trim knobs
I think that's a good fix for the F8 knobs if it doesn't require glueing.  SD knobs have setscrews.  I've done lots of swaps with them, like having earier to read black 302 knobs on a 744 etc.  Nice that they fit on the F8, would be easier to use for sure.  You can buy spare knobs easily from SD, no butchering needed.
These are the other 2 pictures posted, it doesn't look to me that you can screw the SD knobs, the shaft looks too small, so I presume or they pop in, or they need to be glued..... (not so good then)
But for sure even if they are still small, it must be way more comfortable to turn them
BTW the knobs look to me like a thirdparty version rather than original SD
On 1/7/2016 at 11:21 PM, Olle Sjostrom said:
+1
Samuel from zoom said in this very thread to not exceed 16v as it may damage the recorder.
Hey, I run mine with dual npf970 batts at 16.4V when fully charged and it does fine. Sam's post says not to exceed 17V. Nomad's maximum input voltage is 18V so that's not a whole lot higher.
