Allen Rowand Posted February 22, 2018 Report Posted February 22, 2018 47 minutes ago, Michael Wynne said: back to the MS convo, it appears the latest firmware update v1.53 states under fixed "Incorrect gain values when channels are MS linked" So I can only assume that the ISO's are still being recorded as decoded LR file when linked ? To me this doesn't make sense since you already have the LR record bus for that option. So you end up loosing the ability to monitor / preview a raw mid side to see how it's working when recording. What I do is use regular linking on channels 1-2 and a custom headphone preset to monitor 1-2 with M/S decoding. That way I listen to the decoded signal on site but the isos are recorded raw for the most flexibility in post. Quote
Mobilemike Posted February 22, 2018 Report Posted February 22, 2018 39 minutes ago, Allen Rowand said: What I do is use regular linking on channels 1-2 and a custom headphone preset to monitor 1-2 with M/S decoding. That way I listen to the decoded signal on site but the isos are recorded raw for the most flexibility in post. I do the same. I do wish there were away to record both the decoded and raw tracks simultaneously however. I would love it if the isos were true isos - recording the input signal only - and any processing happened only to the stereo bus. To my knowledge though all of the SD products 6-series and newer work this way though, where m-s linking affects isos too. -Mike Quote
KRF Posted February 22, 2018 Report Posted February 22, 2018 On 01/02/2018 at 8:33 PM, bary555 said: How long does it run on li-ions? About the same as eneloop pro. Somewhere around 120 minutes with one phantom power channel. Quote
Roland Harris Posted February 22, 2018 Report Posted February 22, 2018 5 hours ago, Allen Rowand said: What I do is use regular linking on channels 1-2 and a custom headphone preset to monitor 1-2 with M/S decoding. That way I listen to the decoded signal on site but the isos are recorded raw for the most flexibility in post. Ditto re MS decoding to LR to headphones while recording the M and S as isos, but I don't use stereo (your 'regular') linking unless the mics have identical output (and my MS pairs rarely do). Cheers, Roland Quote
Allen Rowand Posted February 22, 2018 Report Posted February 22, 2018 3 hours ago, Throwback said: I don't use stereo (your 'regular') linking unless the mics have identical output (and my MS pairs rarely do). Good point, I use a single M/S mic. Quote
Michael Wynne Posted February 25, 2018 Report Posted February 25, 2018 On 2/21/2018 at 11:14 PM, Allen Rowand said: What I do is use regular linking on channels 1-2 and a custom headphone preset to monitor 1-2 with M/S decoding. That way I listen to the decoded signal on site but the isos are recorded raw for the most flexibility in post. Thank you Allen ! Quote
audiofp Posted March 1, 2018 Report Posted March 1, 2018 I liked the grommet idea. Found this at Ace, part #405942-M. I.D. 5/16". Gives you a nice big diameter and still allows push to select. Quote
Paul Garafola Posted March 2, 2018 Report Posted March 2, 2018 Thanks, AudioFP. Very helpful! I'm going to try this. Quote
msimonson Posted March 14, 2018 Report Posted March 14, 2018 couple questions I've had working with the MixPre for a little bit: 1: Can you store numerous take names like you can on the 744t? I haven't figured out how. I've created presets where a certain take name is default, but it seems like I have to type in a new name if I want to change it while still in one preset. 2: Can you scroll through your headphone presets using the right dial like on the 744t? I know I can access them through the menu, but that headphone rotation on the 744t is sure handy. Quote
josephboyle Posted March 14, 2018 Report Posted March 14, 2018 On 3/1/2018 at 3:49 PM, audiofp said: I liked the grommet idea. Found this at Ace, part #405942-M. I.D. 5/16". Gives you a nice big diameter and still allows push to select. Do you happen to have a link to this part? Or do you know what the part is actually for or what it is called? I went to an Ace and have looked online but can't find it. Looks like a good solution though! Quote
13324 Posted July 29, 2018 Report Posted July 29, 2018 Timecode question for the MixPre-3: I recently recommended the MP3 to a videographer, and he needs to input timecode from a Denecke SB-T, which outputs via BNC. Would this BNC-to-⅛ inch cable from Timecode Systems work? Just making 100% sure. Quote
borjam Posted September 3, 2018 Report Posted September 3, 2018 I just found a bug (MixPre 3, fw version 2.21). I've sent it to SD, but sharing here because when it hit me it looked like I had a defective preamp. Workaround included. When linking channels 1 and 2 in stereo, after unlinking them while keeping channel 2 (which, when linked, is a balance control) centered, channel 2 seemed noisier. Turns out some gain offset is applied to it, and channel 2 has a higher gain than channel 1. This at least happens with the gains in Basic mode (the rest of the options are in Advanced mode). The workaround is simple: after unlinking, if this condition occurs, set the channel 2 input to Line and back to Mic. It will reset the preamp properly. Quote
Allen Rowand Posted September 11, 2018 Report Posted September 11, 2018 Got an email from Sound Devices this morning: View this email in your browser Come See Us in Amsterdam for IBC 2018! Sound Devices is celebrating 20 years of excellence at this year's IBC (stand 8.A32). We'll be exhibiting our highly portable, extremely versatile MixPre Series of audio recorders, mixers, and USB audio interfaces. Both Classic and M-models in the multi-faceted series will be showcased, along with the Professionals' standard, Sound Devices' 6-Series mixer/recorders and Audio Limited's A10 Digital Wireless System. In the spotlight is the upcoming, highly anticipated MixPre version 3.00 firmware, which adds: Support for a new Ambisonics plugin for MixPre-6 and MixPre-10T Full MixPre Series integration support for four 3rd-party USB fader controllers Wireless remote transport control & monitoring of M models & Musician plugin via Wingman App on iOS &/or Android mobile devices Stop by Stand 8.A32 to see what else we unveil! Hopefully v3 will also fix a couple of bugs… Quote
Constantin Posted September 11, 2018 Report Posted September 11, 2018 4 hours ago, Allen Rowand said: Full MixPre Series integration support for four 3rd-party USB fader Very very curious about this, and potentially very very excited, too. Especially if they‘ll add more interfaces, or better yet, open up the protocol for anyone to develop a controller Quote
Allen Rowand Posted September 11, 2018 Report Posted September 11, 2018 1 hour ago, Constantin said: Especially if they‘ll add more interfaces, or better yet, open up the protocol for anyone to develop a controller When I asked them to elaborate on the USB descriptor the MP6 was looking for so that I could control it with a keyboard emulator I was told that was "engineering data" and that I should use a recommended keyboard. That doesn't really work for me, as I'm building a remote to start and stop the MixPre and my Blackmagic camera simultaneously. I agree it would be great if they'd publish the protocols and let people get creative. The other issue is that the MixPre 6 doesn't work with a USB hub between it and the keyboard, meaning we'll have to choose between a controller and keyboard. It'd be nice if Wingman was updated to act as a virtual keyboard to get around this… Quote
Dave Posted September 12, 2018 Report Posted September 12, 2018 Hi All, Happy to hear about being able to add an off the shelf fader panel with the new MixPre Firmware Update. This Korg nanoKONTROL Studio https://www.sweetwater.com/store/detail/nanoKONTStu--korg-nanokontrol-studio seems like it might be good, as far as connectivity goes. I hope it would connect to a MixPre 10T via Bluetooth which would leave the MixPre's USB port available as usual for the USB backup flash memory. Looks like the nanoKontrol can be powered by 2 AA batteries - hope Sound Devices allows a direct Bluetooth connection similar to Wingman. Regarding the new Sennheiser Ambeo features/support, Sweetwater has an interesting series of Ambeo workflow videos here : https://www.sweetwater.com/store/detail/AMBEO--sennheiser-ambeo-vr-microphone The 2 gentlemen in the videos did a very thorough job of showing the Ambeo process from beginning to end - love it when a manufacturer presents workflow so cohesively.... great job on this. When you watch the clip called "A Proximal Visit - TRANSIENCE", click, hold and drag your mouse cursor around to hear the sound perspective change with the video perspective.... kind of cool intro into the possibilities of VR audio. :-) Thanks all---- keep well. Cheers, Dave Quote
Mobilemike Posted September 12, 2018 Report Posted September 12, 2018 1 hour ago, Allen Rowand said: It'd be nice if Wingman was updated to act as a virtual keyboard to get around this… Wingman does act as a virtual keyboard AFAIK. I certainly use it to rename channels, edit file names, enter metadata, etc., in addition to starting and stopping recording. Is there something else a keyboard can do that Wingman can't? I've never needed a keyboard personally. I love the support for fader controllers! Thats what I've been hoping for since the MixPre's were released! I can't say I'm too fond of the specific controllers they support yet though - they all seem to have very short throw, plastic faders. I'd love one with some nice long throw faders on it, so a big +1 to adding more options and/or opening up the protocols. -Mike Quote
IronFilm Posted September 12, 2018 Report Posted September 12, 2018 11 hours ago, Allen Rowand said: Full MixPre Series integration support for four 3rd-party USB fader controllers Oh! Big news, will give an alternative to Zoom's F Controller. Quote
Allen Rowand Posted September 12, 2018 Report Posted September 12, 2018 2 hours ago, Mobilemike said: Wingman does act as a virtual keyboard AFAIK. I certainly use it to rename channels, edit file names, enter metadata, etc., in addition to starting and stopping recording. Is there something else a keyboard can do that Wingman can't? I've never needed a keyboard personally. You can't create or rename projects from Wingman (unless I'm missing something) and you can't rename presets. It's not a show stopper, but it would be nice to be able to rename anything on the unit using a larger touch keyboard on my Nexus 6 instead of the tiny onscreen keyboard. Quote
Allen Rowand Posted September 15, 2018 Report Posted September 15, 2018 Video of Paul Issacs at IBC talking about v3, and he drops a major bit of news- MixPre is getting preroll! 10 seconds on the MP10, 5 seconds on MP6 and 3. Also details Ambisonic and fader support. Need to click through, can't embed the video: https://vimeo.com/290032752 Quote
13324 Posted September 15, 2018 Report Posted September 15, 2018 Here’s some links to the four supported USB controllers: Korg nanoKONTROL Studio Product page Average price: $149.99 USD Controls: 8 faders, 8 pots, 32 buttons Korg nanoKONTROL2 Product page Average price: $59.99 USD Controls: 8 faders, 8 pots, 24 buttons Novation Launch Control XL Product page Average price: $149.99 Controls: 8 faders, 24 pots, 26 buttons Akai MIDImix Product page Average price: $99.99 USD Controls: 9 faders, 24 pots, 16 buttons Quote
Pedro Anacleto Posted September 15, 2018 Report Posted September 15, 2018 I wonder if we will be able to use the jog wheel on the Korg nanoKONTROL Studio to scrub the audio playback. Quote
Mattias Larsen Posted September 16, 2018 Report Posted September 16, 2018 2 hours ago, Pedro Anacleto said: I wonder if we will be able to use the jog wheel on the Korg nanoKONTROL Studio to scrub the audio playback. that would be amazing! But probably not Quote
IronFilm Posted September 16, 2018 Report Posted September 16, 2018 13 hours ago, Allen Rowand said: Video of Paul Issacs at IBC talking about v3, and he drops a major bit of news- MixPre is getting preroll! 10 seconds on the MP10, 5 seconds on MP6 and 3. Also details Ambisonic and fader support. Need to click through, can't embed the video: https://vimeo.com/290032752 Oh yay! Did seem like madness to me that the MixPre series was lacking PreRoll. Quote
