About S Harber
- Birthday January 1
People's Republic of Silverlake
I record and mix actors talking in front of cameras.
No
7,910 profile views
Access has been fantastic to me through the years. https://www.accesscasters.com/
Biscuit Rigs on the rise? Challenges & Approach
S Harber replied to Michael Wynne's topic in Workflow
Post doesn't care if you roll and cut so... Make sure to tell your talent that you will not always be able to roll and cut so they should not say anything too off. Drop the bag rig in the car in automix. Attach a Comtek mini mite on the top of the car and go have a nice ride in the pass van. Easy. This is how I did many season of Bosch which had tons of driving with a pod car. Mixing for optimal dailies is a bad rationale for risking no reception. No one cares about the quality as long as things are SOLID, and post will love having a solid unbroken track on their timeline. -
I love Glensound other than they don't seem to design around DC considerations for powering much.
Thanks for that Jason. Very appreciated. SH
Very cool offset there. Do you happen to have the STL file for that? My son is very dialed into printing so hopefully... Thanks in advance. SH
I have something like this to see what each item draws on my cart wired to 4 pin xlr etc. A great tool to have around and to see what gets used. https://powerwerx.com/watt-meter-analyzer-inline-dc-powerpole My older Venue 1s draw 1.12A/15Watts Here's a chart of what I use on my carts, what the items draw, and how long they should run off their respective carts batteries. DC CART USAGE.pdf
If it's truly that wet I'd dedicate a housed phone and use Timebar with a Tentacle and forgo the ID aspect of writing on the slate. The numbers for sync will be there. Post as well as script/AC/mixer can name takes etc via other means. If you have a VTR person ti makes things even easier.
Asking for a friend. They need a mixer/recordist for an audio only interview. The location is on the coast SE of Orlando. Chris is the producer. chris@loadedpictures.com Thanks!
Sorry to say, but the Airpod Pros are notorious for horrible sounding mics. I found this out and tried various noise canceling settings and the like to resolve it. Lots of posts online about these issues and folks problems. If I want to talk, I use the regular AirPods so I don't sound underwater or whatever version of bad the Pros had. SH
Hi All, Not sure why there is an absence of discussion surrounding the current state of IATSE contract negotiations on this site. This seems very strange seeing what we all do for work. I know there are other forums ie FB, IG IA stories etc. but it seems like a huge hole given what it all means to many here. Is there some sort of dissuasion to this kind of discussion on JWS? Me? I personally think we need to show that we are willing to hold the line and get our various demands engaged and have most of them met to increase our quality of life. Sad to say but nothing will change without costing production more. Now it's not costing them enough to not pay the penalty of doing the right thing. This has become a regular occurrence and no one will change their ways out of the "goodness" of their hearts. But....they will if it simply costs more since it's simply a business. Thus I believe we need to up the rates of going over the lines that make it safe and keep us sane. These raises should not be seen as ways of making more money but rather to push productions into making decisions that help us all work better. There will never in our lifetimes be an opportunity to have the strength we presently do. The need for programming and movies is higher than ever and the folks producing will never be as desperate as now to generate our product. Let's stay together and support each other as we head into this. I realize I sit in a position of privilege on many levels. I have worked all through the covid shutdown and have years of contacts, previous work, savings, and hours accumulated. That said, I obviously want to make things better for myself but AS important, is to leave this place better than I found it for others. I very much empathize with those who had no work for a long time and are starting their journey in this field. We were all there in one form or another so let's show support for each other rather than side up and lob bombs. Scott Harber CAS
What I did on my 8020 cart was to use 15-15 in general and then 15-30 for the axle. Cotter pins are used so that there is NO chance of a wheel nut unthreading. A bad lesson to be learned there unless you reverse thread one side like bike pedals. I used a simple 5/8" piece of solid steel for the axle which I then wrapped to snug it in tight in the top of the 2 holes in the 15-30. It's nice to be able to use the 2 holes vertically so you can adjust the height if need be. Hopefully the pic I zoomed in on shows some of what I'm referring to. Again, nuts on axles are a bad idea. Just sayin. SH IMG_9773.pdf IMG_D30947E031EE-1.pdf
I have the 442 inputs roughed in to replicate the gains I start with on the wireless Booms to keep consistent gain structure. It can vary from there. We can almost always pull it off with a 100' stick of CAT5/Ethercon but we carry 300' total between the mixer cart and set rack. Here's some early pics from when I had the MM1 rather than the 442 when we were doing Bosch at the end of last year. IMG_8640.pdf 1479467755_IMG_93292.pdf
This is a diagram for a rig I built last year with the A32 Ferrofish in an 8 RU SKB case. It's packed in with a 20aH battery and a 442 for hard lining mics if need be. The biggest trick was getting the USB over IP Silex 510 system to be bulletproof so I could feed the telemetry for the Venues back to my mixer cart. I've linked 400'+ of CAT 5 and it stayed stable overnight. That said, I've yet to need that long of a run. It keeps me off set and is much easier than running antenna cable and also puts TC and return feeds right on set. I use a Cisco SG 3000-10 switch on my mixer cart which dates back to PIX setups from my past. It works well and isn't maxing out the Netgear 5x switches I generally pepper around. Hope this diagram helps. SH Set Forward.numbers-Routing.pdf
Hi Steve, I remote my Venues in a rack that goes to set and keeps me away from the density of the area around set. It also helps us not have to run antenna cable and has it's own battery and power supply. My Cantar has Dante and I can run the outputs of the receivers to a Ferrofish converter that makes the analog outs of the Venues into Dante which then cables back to my mix cart. The Dante runs seamlessly and we unplug it and rearrange it many times each day. I've managed to get the telemetry of the Venues to run in WirelessDesigner as well via a USB to IP converter which then goes to my laptop. The schematic is attached and there's plenty going on including power and a feed back to the rack for an IFB transmitter etc. SH Set Forward.numbers-Routing.pdf
