I read that the Sonosax SX-R4+ recorder differs in the USA from the European version. Is it the same for the SX-M2D2 that the US version is different from the European one?
  • 4 weeks later...
6 hours ago, AB said:
To be clear, this is not a recorder, correct?
Correct, it doesn't record. (although you could use something as simple as your phone over USB to record together with it)
I got that.
So wonderful quality.
Back is full of male like 80's SF convention.This is easy to clean.
It cannot bypass AD/DA , cannot send balanced line signal.
but seems to be a trivial matter.
On 2/8/2020 at 6:18 PM, Jeremtools said:
Hello everybody,
Has anyone found a compatible bag or a solution for use with an orca-type bag for example?
thx
jeremie
This is how I use it. Orca is still not making bags for it but even if it will it will cost:-) I use a modified pouch (with my older Petrol soft pads) found on Amazon: https://www.amazon.com/AIRSSON-Universal-Organizer-Smartphone-Carabiner/dp/B07VJG3NSY/ref=redir_mobile_desktop?ie=UTF8&fbclid=IwAR0LNz2In64bKDexBYMdiSgTzJILMJUxXdL4tkhCWxKAspxddZyvSWhwEp0&psc=1&ref=ppx_pop_mob_b_asin_title
  • 1 month later...
On 2/19/2020 at 2:02 AM, Michael Goorevich said:
Thanks for the link Michael.  How do you run cables to the M2D2 when it is in this pouch?
On 3/28/2020 at 3:31 PM, David Lawrence said:
I use my M2D2 with my ORTF setup (a pair of mkh8090 mics) which has a 5 pin connector on the Rycote handle.
I got a low profile 2x mini-XLR running from M2D2 into a small hole I did in internal fabric through the pen compartment and to the Rycote.
Then a low profile or right angle USB C cable goes into other compartment where it connects to the Camera to Ligthing adapter and to the iPhone.
My HD25 cans have a right angle connector as well. So everything is highly accessible and easy to use with no stress on the cables.
I modified a Peak design bag (the field pouch) and this is what it looks like. And once the recordings are done, everything goes inside! (except the headphones ok ..)
I use the iPhone as a recorder and there is a small power bank that powers the M2D2 and the iPhone.
Is that another mirror shot? Yes yes I know ... Red is Right these days! (...Friendly Fire...?)
But for those yet to jump on the treadmill ... Red Port Left, Green Starboard Right, as per my Nagra and Neve PPMs (and every ship and plane in existence).
Salut, Jez
1 hour ago, Patrick Tresch said:
It basically would need a power on/off and a REC button. Would love to see it from Tentacle.
They're bringing out an ultra small recorder, but I assume it would be via the 3.5mm input, not USB
1 minute ago, henrimic said:
If Sonosax could ad a simple SD card and a recording function, for the version 2, that would be huge !
+1, yep, yes and definitely. I'm pretty sure so many of us would have bought 1 in a heart beat if had a built in recorder. I'm not going to say they missed an open goal because maybe there was something like a legal reason not do this - anyway here's to something like an R2D2 if ever happens.
